21615 Discussions
MAX10 embedded memory contents after reconfiguration
Ky8
Hello.
I will use embedded memory as "RAM:1-PORT" or "RAM:2-PORT" on MAX10 device.
If I reconfigure MAX10 device using same configuration data under correct supplying power,can that memory hold the data contents before reconfiguration in after of reconfiguration?
Thank you.
NurAiman_M_Intel
Thank you for contacting Intel community.
This is to let you know that I am currently checking this with my internal team. I will get back to you once I have the findings.
Aiman
Ky8
Hello Aiman,
Thank you very much.
I understood.
If you get the findings, please let me know.
Thank you.
Ky8
SyafieqS
Hi Kei,
There is no information for this in doc. Have you test it at your end what is the behavior of it?
Ky8
Hello SyafieqS_Intel,
I only had a question but I did not test it.
Thank you for telling me that there is no information for this in doc.
I understood using like so was not guaranteed.
Because device manufacturer does not guarantee it, I do not intend to use the function even if such a behavior is observed.
Thank you very much for your kind reply.
