21611 Discussions
MAX10 pin too close to PLL clock
Hi all,
I install a new Quartus 16.0 and faced with the problem that the project compilation with error message.
Error (18496): The Output CH4_TXCO in pin location 29 (pad_9870) is too close to PLL clock input pin (CLK_48MHz) in pin location 28 (pad_2)
The project uses family "MAX 10", device 10M08SAE144C8GES.
The Quartus 15 .1 project compiles fully, without errors.
How to solve a problem ? Use only Quartus 15.1 ?
http://www.alteraforum.com/forum/attachment.php?attachmentid=12213&stc=1
I have the same problem. Is there any solution?
You need to change CH4_TXCO pin location away from PLL clock input. SI affects to this pin because of close location to PLL clk input. So Fitter occurs error.
This error not occurs in Quartus 15.0 SW. So it have to have another solution.
Maybe device characterization seems be changed, adding restrictions. I don't know the reason.
I have the same question, is there any other way to solve it?
Quartus 16.0 version will appear if using ALTPLL …………
Here is the error cause, could you read this link?
http://sw-web.altera.com/tools/quartuskit/16.0/current.linux64/linux64/quartus/common/help/webhelp/index.htm#msgs/msgs/efiomgr_output_too_close_to_pll_clock_input.htm
Use another pll ref_clk input, or create clock from other pll, or change the error target pin location.
I don't think all IO standard user IOs are prohibited adjacent to PLL clk in, I gues some IOs are restricted due to affection of switching noise.
the is case is actually documented in the MAX 10 FPGA Signal Integrity Design Guidelines (https://www.altera.com/en_us/pdfs/literature/hb/max-10/m10_sidg.pdf#page=7). The only way I can think of to get a solution for this issue in 16.0 is to file a service request.
Cheers,
fade
i have the same problem that you had. At the end how did you solve it?
thank you for your answer
Riccardo
--- Quote Start ---
Riccardo
--- Quote End ---
Hi. To solve "Error (18496)" need use Quartus 15.1 or re-design of PCB. :(
