21607 Discussions
MAX10 programming and verification very slow
YDu00
I am using Max10 FPGA. programm SOF file is fast. programm POF file is a little slower, but acceptible. However, after programming POF, it takes 20 minites for the programm verification process. Is this reasonable?
YuanLi_S_Intel
Hi Yong Jiu,
Programming of SOF is faster than POF and this is legit. The reason is because SOF is volatile and POF is non-volatile.
You mentioned about 20 min program verification, what is that? Is that a time in programming a MAX10 or boot up a MAX10?
Thank You
YDu00
Please see the following system info.
"Info (209023): Programming device(s)" this step takes 1 minute.
BUT, "Info (209021): Performing verification on device(s)" ,this step takes 20 minutes.
YuanLi_S_Intel
Hi Yong Jiu,
Yes, programming itself is fast. But when the other option is enabled in Quartus such as verification and examine, the time is longer.
Thank You.
YDu00
Thanks. But is it normal to take 30 Minutes?
YuanLi_S_Intel
Hi Yongjiu,
Sorry for late as i was checking with internal team. Yes, it can be and depending on the size of the bitstream as well.
Thank You.
