21615 Discussions
MAX10 programming problem
DZabr
Hello! I am trying to program my max10 device
I tried to program with .sof through Quartus programmer 18 and it went well, both verilog and nios part worked.
But when I try .pof I got:
Info (209060): Started Programmer operation at Tue Oct 08 15:19:14 2019 Info (209017): Device 1 contains JTAG ID code 0x031830DD Info (209060): Started Programmer operation at Tue Oct 08 15:19:16 2019 Info (209016): Configuring device index 1 Info (209017): Device 1 contains JTAG ID code 0x031830DD Info (209007): Configuration succeeded -- 1 device(s) configured Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Tue Oct 08 15:19:17 2019 Error (209012): Operation failed Info (209061): Ended Programmer operation at Tue Oct 08 15:19:23 2019
I tried creating .pof with "Converting programming files" and the result was the same. Is there any suggestion to this problem?
Ahmed_H_Intel1
There are many things may cause this issue, Can you please check if you are choosing the correct Flash device and the boot settings?
Which board you are using? I recommend you try to download one of the examples below and see the difference between what you are doing and what inside these examples. Or I offer you to create a simple NIOS design (Hellw World) on one of the MAX 10 Dev-kits.
DZabr
Unfortunately, I have no Dev-kit boards, it is my own device. I checked forum and found a man https://forums.intel.com/s/question/0D50P00004K8maLSAR/quartus18x191-issue1-programmer that had successful programming with programmer version 15. We tried, and it works! But still no luck with version 16 and 18. Well, at least it works there.
