21615 Discussions
Help using transceivers in HDMI-port on Arria V GX starter board to send TMDS data
I am working on a project where I want to send TMDS data to a monitor using the HDMI-port on my Arria V GX starter board. I have only limited experience form VHDL design and have also only worked with Xilinx before, and never transceivers.
I am using a Arria V GX starter board with a 5AGXFB3H4F35C4N FPGA and Quartus II 13.0.
For a couple of days I been trying without success to send something using the 1.5-VPCML transceivers.
What I want to achieve is to send 3 x 10bit that comes in parallel at 148.5Mhz using 3 transceiver lanes sending at 1485 Mbps. I also want to send the 148.5Mhz clock over a transceiver output.
Whether I am trying with one or more lanes I am stuck with these errors and critical warnings respectively:
Error (175020): Illegal constraint of Transmitter channel to the region (169, 11) to (169, 11): no valid locations in region Info (175028): The Transmitter channel name: hdmi_tx_p Error (175005): Could not find a location with: PMA_DIRECT_CHANNEL (1 location affected) Info (175029): Transmitter channel containing PIN_AJ3 Info (175015): The I/O pad is constrained to the location PIN_AJ3 due to: User Location Constraints (PIN_AJ3)
Critical Warning: HSSI PMA TX Serializer port 'CLKDIVTX' on node PHYnat_Tx:Trans|altera_xcvr_native_av:phynat_tx_inst|av_xcvr_native:gen_native_inst.av_xcvr_native_insts.gen_bonded_group_native.av_xcvr_native_inst|av_pma:inst_av_pma|av_tx_pma:av_tx_pma|av_tx_pma_ch:tx_pma_insts.av_tx_pma_ch_inst|tx_pma_ch.tx_pma_ser should be connected Info: Must be connected Critical Warning: HSSI PMA TX Serializer port 'CLKDIVTX' on node PHYnat_Tx:Trans|altera_xcvr_native_av:phynat_tx_inst|av_xcvr_native:gen_native_inst.av_xcvr_native_insts.gen_bonded_group_native.av_xcvr_native_inst|av_pma:inst_av_pma|av_tx_pma:av_tx_pma|av_tx_pma_ch:tx_pma_insts.av_tx_pma_ch_inst|tx_pma_ch.tx_pma_ser should be connected Info: Must be connected Critical Warning (11087): PMA direct channel(s) detected and needs to be constrained based on the guidelines in Arria V Device Handbook Volume 3: Transceiver chapter Critical Warning (184043): Fitter was unable to find Transceiver Reconfiguration Controllers associated with the following 2 XCVR PHY IP component blocks Info (184044): Avalon Memory Map block PHYnat_Tx:Trans|altera_xcvr_native_av:phynat_tx_inst|av_xcvr_native:gen_native_inst.av_xcvr_native_insts.gen_bonded_group_native.av_xcvr_native_inst|av_xcvr_avmm:inst_av_xcvr_avmm|avmm_interface_insts.av_hssi_avmm_interface_inst Info (184044): Avalon Memory Map block PHYnat_Tx:Trans|altera_xcvr_native_av:phynat_tx_inst|av_xcvr_plls:gen_native_inst.av_xcvr_native_insts.gen_bonded_group_plls.gen_tx_plls.tx_plls|pll.avmm.av_hssi_avmm_interface_inst Error (175020): Illegal constraint of Transmitter channel to the region (169, 11) to (169, 11): no valid locations in region Info (175028): The Transmitter channel name: hdmi_tx_p Error (175005): Could not find a location with: PMA_DIRECT_CHANNEL (1 location affected) Info (175029): Transmitter channel containing PIN_AJ3 Info (175015): The I/O pad is constrained to the location PIN_AJ3 due to: User Location Constraints (PIN_AJ3)
And some additional warnings which I think are irrelevant.
I am using a Native PHY IP core in direct PMA mode and have assigned the pins the I/O standard 1.5-VPCML. What might be the problem? Am I on the completely wrong track?
Your help will be highly appreciated!
Aron
How is your 3 transceicer channels placed? It seems like the hdmi tx[0] is placed to invalid location. Do u refer to the referencen manual to set the pin assignment correctly?
--- Quote Start ---
--- Quote End ---
I am unable to check my design now but can take some screenshots tomorrow. But yes, I have the positive part according to the reference manual and set them to 1.5-V PCML. The software then adds the negative part automatically.
I may also add that the error codes above are form a 1 lane test, but I get the same errors (but more) with more lanes.
You may need to test on one channel design first.
so I suppose you havehdmi_tx_p [0], hdmi_tx_p [1], and hdmi_tx_p [2] since u have 3 channels right?
Yes I am trying with one channel first now. I have those and also one channel for clock. The HDMI pins can be seen in the table 2-41 at page 46 altera.com/literature/manual/rm_avgx_starter_board.pdf
Might it have to do with constraints that I need to define in a .sdc file? I know nothing about this and can't find anything in the handbook about ut. I also have "a new project" based on the golden top where I just use a native PHY and try to send something over a single channel. Still the same (relevant) errors and warnings though:
Critical Warning (11087): PMA direct channel(s) detected and needs to be constrained based on the guidelines in Arria V Device Handbook Volume 3: Transceiver chapter Error (175020): Illegal constraint of pin to the region (169, 23) to (169, 23): no valid locations in region Info (175028): The pin name: hdmi_tx_clkout_p Error (184016): There were not enough differential output pin locations available (1 location affected) Info (175029): pin containing PIN_AC3 Info (175015): The I/O pad is constrained to the location PIN_AC3 due to: User Location Constraints (PIN_AC3) Error (175020): Illegal constraint of Transmitter channel to the region (169, 11) to (169, 11): no valid locations in region Info (175028): The Transmitter channel name: hdmi_tx_p Error (175005): Could not find a location with: PMA_DIRECT_CHANNEL (1 location affected) Info (175029): Transmitter channel containing PIN_AJ3 Info (175015): The I/O pad is constrained to the location PIN_AJ3 due to: User Location Constraints (PIN_AJ3) Error (12289): An error occurred while applying the periphery constraints. Review the offending constraints and rerun the Fitter. Error (11802): Can't fit design in device
The error message does not seem related with SDC, but seem like the same pin is assigned to 2 location or fitter trying to merge two channel into same location.
Do you have any special setting in the qsf?
--- Quote Start ---
--- Quote End ---
I am pretty sure that my assignments are correct. I have assigned the positive nodes and the software automatically assigns the negative nodes to the correct pins. I recently talked shortly to a friend and he also made me think that it might be something with how I declare the IP-cores in the .qsf. I have not done anything in the file at all, and the way that I have declared the IP-cores is like components and then "port map", is that wrong?
Are you using pma direct? Or what transceiver configuration are you using? Seem like error point to your pma direct channel
--- Quote Start ---
--- Quote End ---
Yes, PMA direct. Anything special I should do? It seems to be the easiest way but maybe I am missing something?
I am not too sure whether is there limitation for pma direct for hdmi pin, can u try to use other phy like native phy
I am using native PHY in direct PMA mode, but do you mean that it could work better if I use PCS?
I found this:
http://www.altera.com/support/kdb/solutions/rd08272012_320.html
Even though it is not the error codes I get it seems to indicate that my FPGA doesnt support PMA direct mode? That is strange though, because I am pretty sure that I have seen tables that show that it do support direct PMA.
You may try to turn on PCS but bypass anything and see whether that works
Hi Arion,
Were you able to get your design working? I also have an Arria V GX Starter Kit that has an HDMI Rx HSMC daughtercard from Terasic connected to it. I want to do a simple pass-through design where the parallel video output from the daughtercard is sent to the HDMI Tx port on the board. Since there's no real HDMI transmitter chip on the board, I need to serialize the data myself.
Lloyd
If I am not mistaken, Arria V GX not support PMA direct, and it is only supported in Arria V GT device.
You may quickly test out but create a simple PMA direct and compile in quartus to see whether it can pass fitter.
Timmio
Does anyone solve this problem? I really want to send TMDS on Arria V GX Starter kit.
