21611 Discussions
Max 10 IO status when Jtag Programming
Hi there,
I use Max 10 10M04DAU324 Series FPGA in our design.
Only I konw that IO status keeps tri-state with internal weak pull-high when CFM to SRAM(config mode) as attachment picture showed "2".
I wonder the IO status keeps tri-state OR remain high when JTAG programming status as attachment picture showed "1".
Is there have any official doc can prove IO status at JTAG programming on Max 10, thanks.
--- Quote Start ---
In a normal ISP operation, to update the internal flash with a new design image, the device exits from user mode and all I/O pins remain tri-stated.
--- Quote End ---
Whenever the device is not in user mode all I/O are tri-stated. This includes when the device is being configure via JTAG.
See the 'max 10 fpga configuration user guide (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/max-10/ug_m10_config.pdf)'.
Cheers,
Alex
Hi Alex,
'MAX 10 FPGA Configuration User Guide' doen't specified IO status when jtag programming, I do some experiment at MAX® 10 FPGA Evaluation Kit with checking set IO remaing weak-pull high piror User Mode(default is pull high), and have strange things happend, I wonder that is Quartus 16.1 tool's bug.
Are you using the ISP Clamp feature?
Cheers,
Alex
Hi Alex,
No, But I know that ISP Clamp is workable. Discussed with Altera AE, they still test on this problem.
