21586 Discussions
Max II simulation with M29EW FLASH
nome
Hello
I totally don't know about how to use simulating in modelsim m29ew(JS28F256M29EWxx) module along with maxii cpld
However according to ug_pfl in topic flash memory simulation they said that ask verilog module from vendor i got it from micron and now my question is
1.how to write option bit in flash module?
2 . how flash module coordinate with pfl?
do you have any information excpet ug_pfl please share us
nome
ShengN_Intel
You can refer to the manual below for further information.
Manual here
Sheng
nome
Hello
Thanks for your Reply
Above link doesn't access errors occur  please send us file via PM or by Email:scs@technologist.com
Nome
ShengN_Intel
Hi there,
Done emailing you.
You may register here https://www.intel.com/content/www/us/en/documentation-resources/developer.html#panel-top-resources|most-popular as well  to access more related resources and documentations.
Sheng
nome
Hi
Thanks for sharing
sir as i mentioned in my first post ug_pfl.pdf has not not enough information about corrdination between flash and PFL .
best regards
nome
ShengN_Intel
Hi nome,
I found these two manuals as well which related to flash module and pfl at part 3.1.7:
Manual 1 Manual 2
Here is a related video link.
https://www.youtube.com/watch?v=uRP6zip-MLs
You may register here https://www.intel.com/content/www/us/en/documentation-resources/developer.html#panel-top-resources|m... for further searching and documents accessing.
Sheng
nome
hello
Sir my question was "how to use simulating in modelsim m29ew(JS28F256M29EWxx) module along with maxii cpld"
in ug_pfl has not enough information regarding simulation
best regards
nome
ShengN_Intel
Hi nome,
I'll try to get in touch with internal team to see whether there is any other more detailed documents about that or not. Will come back to you once there is any feedback from them.
Sheng
nome
Hello brother
I will waiting your reply
Best Regards
Nome
ShengN_Intel
Hi nome,
From internal feedback, those are the most detailed and related documents on how to write option bit in flash module and how flash module coordinate with pfl so far.
Sheng
