21602 Discussions
Max V, dual speed grade compile
BDegu
I get a different program file when I compile with the 5M80ZT100C4 and the slower C5 device.  Both speed grades pass timing.  I would like to be able to use either device in manufacturing with the same program file.  Is this possible?  What do I need to do?
YuanLi_S_Intel
Yes, it is possible. Programming files are speed grade and temperate grade dependent.
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/solutions/rd02072008_497.html
BDegu
Thanks for the reply.  I am still curios why it is stated that it is speed grade independent when the program files are different when recompiled with the "4" and "5" speed grades.  I'm just going to use the slower, 5, grade and move on.
Best regards, Bryan
YuanLi_S_Intel
Hi Bryan,
May i know what do you mean by programming files are different? The size of the SOF generated?
Best regards, Bruce
