21592 Discussions
Max10 could download .sof file and .pof file from programmer(JTAG), but can not debug through JTAG in SBT.
zbowe1
a simple test program written by SBT IDE, when I debug with it , follow occurs. debug Failed.PNG
zbowe1
how to fix it? usb blaster is good, download is posible.
ShafiqY_Intel
Hi zbowe1,
May I know your NIOS II IP parameter?
if possible, can you send the screenshot og your NIOS II IP parameter.
Matt
zbowe1
Hi, Matt Thank you for your help. Following is the Nios II parameter about jtag, whether it is enough? [cid:image003.jpg@01D6468E.2C1D5AF0] Have a nice day!
zbowe1
could your give me some suggestions about
