21591 Discussions
Max10 remote update bitstream
fogl
Hello everybody,
I would like to remotely update the Max10 bitstream written in internal flash CFM region. I am not sure how can I generate a proper bitstream.
I thought the .pof file can be used for that. I compared the bitstream written in flash to .pof file used for programming and i noticed there is no direct match (i am aware of .pof file header/footer).
I tried to generate the .rbf file, but acoding to information it is not possible for the Max10 devices: https://community.intel.com/t5/Programmable-Devices/rbf-file-for-MAX10-to-use-JRunner/m-p/127064
How can i generate a proper bitstream that can be used to configure the CFM region remotely using the On-Chip Flash IP Core?
Klemen
NurAiman_M_Intel
Thank you for contacting Intel community.
You can refer to AN 741 below for Remote system update for MAX10.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an741.pdf
Aiman
NurAiman_M_Intel
Aiman
fogl
Thank you for your reply, I managed to generate the .rpd file with Internal Configuration Mode Option.
It generated the output_file_cfm0_auto.rpd.
Now I compared the content of this file (output_file_cfm0_auto.rpd) to the data of the same project (same .pof file) written to flash using the jtag cable. I am using On-chip Flash IP to read the data. The data is not the same. Is this expected, I was expecting the same data?
Klemen
NurAiman_M_Intel
The data should not be the same. As POF has header while RBF do not have header.
Aiman
fogl
I am comparing the data written in the internal flash to .rbf file. Is the header of the .pof file also written to the flash during the programming phase - i assume not?
Klemen
NurAiman_M_Intel
The answer is, yes, you will see different data. The header of the POF file also written to the flash during the programming.
Aiman
fogl
OK, thank you clarification and your help
NurAiman_M_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
