21602 Discussions
Maximum Load of a DPCLK Pin of the MAX10
What is the maximum capacitive load which can be powered by a DPCLK output of a Max 10 Device?
I want to use a 10M08SCE144C8G to power 4 ADC clock inputs with a capacitve load of 5pf for each ADC with a frequence up to 20MHz. Is the maximum current equal to normal I/Os?
Thanks for your help
can you try to do a complete compilation and see if it passes?
I'm pretty sure Altera don't publish maximum loads. They only state performance figures based on particular loads - in the case of MAX 10, typically 5pf.
What I/O standard are you looking to drive? DPCLK won't let you drive certain differential signaling standards from it. In that respect it is no different to any other general purpose I/O pin. The DPCLK pins are intended to be used as a low latency control routes in to the device. If you're looking for higher performing clock output pins, look to the PLL_L_CLKOUT pins with lower latency from the PLLs.
Finally, I suspect you should be able to run a 20pF load at 20MHz. Just be careful with your routing if that's split over four destinations.
Cheers,
Alex
You can also try to perform IBIS model simulation to check if with that specific loading, can the toggling rate still meet your requirement or not.
Thanks for your quick response :-)
I want to drive the Clk Inputs of the ADC on a Single-Ended 3.3V CMOS Level.
I think i´ll use the PPL_L_CLKOUT Pin to drive an external clock buffer, just to make sure that i wont get any problems with my clock signals
