Programmable Devices
21611 Discussions
Memory WRITING issue
Dear,
I have a procedure (Sort) that read two numbers in each cycle. and return the max and the min. I am reading two numbers from mif file , the problem is that I want to write back the result returned from the PROCEDURE to the same location of the memory that I had read from. I expected it to be in the next cycle but the memory is not able to be inferred " can't infer memory for variable 'ram1' with attribute '"M4K"'. I listed the code below as reference. Many thanks.
ARCHITECTURE behave OF min_max IS
TYPE MEM IS ARRAY(0 TO 15) OF signed(9 DOWNTO 0);
signal ram1:MEM;
ATTRIBUTE ram_init_file: STRING;
ATTRIBUTE ram_init_file OF ram1: SIGNAL IS "bits.mif";
ATTRIBUTE ramstyle: STRING;
ATTRIBUTE ramstyle OF ram1: SIGNAL IS "M4K";
SIGNAL reg1sig,reg2sig,dataodd,dataeven,minsig,maxsig: signed(9 downto 0);
BEGIN
PROCESS (clock)
variable kk:integer range 0 to 7:=0;
BEGIN
IF rising_edge(clock) THEN
dataodd <= ram1(2*kk+1);
dataeven<=ram1(2*kk);
reg1sig<=dataodd;
reg2sig<=dataeven;
Sort(Reg1sig,reg2sig,maxsig,minsig); -- THE PROCEDURETAKES TWO NUMBERS AND RETURN TWO , IT WORKS WELL WITHOUT WRITING TO RAM1
ram1(2*kk+1) <= maxsig;
ram1(2*kk)<= minsig;
kk:=kk+1;
END IF;
OUT<=maxsig;
END PROCESS;
You can only ever read/write 1 value from a ram in a single clock cycle, not two. Your code reads from 2 locations in a single clock, not possible. You may need to build a ram that stores both values in parrallel if you want to do this.
The ram has two ports, I succeeded in reading two values together , but I couldn't write on these location when I added
ram1(2*kk)<= minsig
--- Quote Start ---
ram1(2*kk)<= minsig
--- Quote End ---
Is that the standard template for dual port ram?
I never use inference so can't answer you but I have this diversion: if you are checking on data stored in mif, why not pre-compute in software to get your mif ready for max/min
The Quartus created the dual port when you have two reads. The mif data is an example, I need a real time implementation of course.
Dual ports means each port can do either write OR read on each port in clock cycle, not both.
See coding style guidelines here:
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/qts/qts-qpp-5v1.pdf
Section 4 (Page 100)
Memory is section 4.4
I will read it and check my code. Thanks a lot.
--- Quote Start ---
--- Quote End ---
I added another process,
ShowResults:Process(Clock,show)
variable i:integer range 0 to 7:=0;
begin
IF rising_edge(clock) and show='1' THEN
D<=ram1(2*i);
S<=ram1(2*i+1);
i:=i+1;
end if;
end process;
acmain<='0' when Z=16 else '1'; --Z is a counter to read 16 elements and then stop activating the first process.acmain is in sensitivity list of first process I listed in first post.
show<='1' when acmain='0' else '0';
So, I activate it when I deactivate the first process , So I can either read or write. However Still unable to infer to memory. What is the best solution for that
This is because you're still reading or writing 2 locations at the same time - the ram1(2*i) and (2*i+1). You can only read/write 1 location at the time.
The weird thing is that I am using dual port , in reading these two locations, it . I am using now different memory for each operations , but the number of logic element is so large . Thank you for your reply brother.
You really need to study the document I provided. If your code doesnt match the template, then a ram will not be infered.
I did and I am still reviewing it. Thank you very much for your continuous help and notes.
