Programmable Devices
21600 讨论
Memory bit not enough for Stratix II EP2S60F672C3
名誉分销商 II
1,170 次查看
Hi All,
I'm designing specialized RAM for my project and is prototype on Stratix II, EP2S60F672C3. Below is my design
module ram (datain, address, we, clk, dataout);
//parameters
parameter row = 4;
parameter column = 4;
parameter data_width = 4;
parameter address_width = (row+column);
//input
input [data_width-1:0] datain;
input [address_width-1:0] address;
input clk;
input we;
//output
output [data_width-1:0] dataout;
//register
reg [data_width-1:0] ram[2**address_width-1:0];
reg [data_width-1:0] dataout;
//behavior descryption
always @(posedge clk)
begin
if (we) //write operation
ram[address] <= datain;
end
always @ (negedge clk)
begin
dataout <= ram[address]; //read operation
end
endmodule
According to my calculation, the memory usage should calculated as below
Memory usage :# address location *# bit in each location
case 1: DATA_WIDTH = 4;
memory usage = (2^8) * (4) = 1024 bits;
case 2: DATA_WIDTH = 36;
memory usage = (2^8) * (36) = 9,216 bits;
but my design would require 1296 bits to store big number, so...
case 3: DATA_WIDTH = 1296;
memory usage = (2^8) * (1296) = 331,776 bits;
Stratix II EP2S60F672C3 has 2,544,192 bits, by right my design can be fit into this device. However, i got an error:
"error: out of memory in module quartus_map (2147 megabytes used)
Anyone has any idea why my design is using up 2147Mb?
Thanks in advance,
ty6
0 项奖励
1 回复
名誉分销商 II
431 次查看
You misunderstand the error message. It's about your PC being "Out of memory" during compilation, not FPGA memory. Assuming your PC has more than 2 GB RAM, then it's a problem of 32 Bit Windows settings. There's an option to enable one more GB for the application, it has been discussed in the forum, and is also mentionend somewhere in a Quartus readme file.
It's also a fact, that "Out of memory" sometimes can be triggered by "impossible" designs, e.g. involding infinite iterations. But your design seems fine.
The "Out of memory" problem has to do with complexity of the used design and FPGA size. To check your design first, you can compile it without specifying a particular FPGA type.
0 项奖励
回复
