Microwin Error
Hi, any one have face this problem before and can share the solution of it? thanks!!!
/usr/local/src/nios2-linux/uClinux-dist/user/microwin/src/engine/font_fnt.c: In function `fnt_load_font':
/usr/local/src/nios2-linux/uClinux-dist/user/microwin/src/engine/font_fnt.c:253: error: `FNT_FONT_DIR' undeclared (first use in this function)
/usr/local/src/nios2-linux/uClinux-dist/user/microwin/src/engine/font_fnt.c:253: error: (Each undeclared identifier is reported only once
/usr/local/src/nios2-linux/uClinux-dist/user/microwin/src/engine/font_fnt.c:253: error: for each function it appears in.)
/usr/local/src/nios2-linux/uClinux-dist/user/microwin/src/engine/font_fnt.c:253: error: syntax error before string constant
make[5]: *** [/usr/local/src/nios2-linux/uClinux-dist/user/microwin/src/obj/engine/font_fnt.o] Error 1
make[5]: Leaving directory `/usr/local/src/nios2-linux/uClinux-dist/user/microwin/src/nanox'
make[4]: *** [subdir-/usr/local/src/nios2-linux/uClinux-dist/user/microwin/src/nanox] Error 2
make[4]: Leaving directory `/usr/local/src/nios2-linux/uClinux-dist/user/microwin/src'
make[3]: *** [all] Error 1
make[3]: Leaving directory `/usr/local/src/nios2-linux/uClinux-dist/user/microwin'
make[2]: *** [microwin] Error 2
make[2]: Leaving directory `/usr/local/src/nios2-linux/uClinux-dist/user'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/usr/local/src/nios2-linux/uClinux-dist/user'
make: *** [subdirs] Error 1
The uclinux-dist I used is "nios2-linux-20100621.tar".
AnyOne know what is happened on this error when build the zImage file? Izit need change any things on the font_fnt.c code to make the FNT_FONT_DIR be declared??
Thanks for reply.
Best Regard
Pang
I try and error many time to make the customization of microwin work, but no success, and can't find any related solution through online like google and baidu...seem like no one have ever success to display the image using the nxview in nano-X to Vga monitor ..Therefore I think can conclude that the microwin customization is won't work in uClinux of DE2 board.....since there are many error that not yet to fix so far ...
If anyone are sucess to make it previous or future time, can share the experience and solution to me as well..Thanks!!
