ModelSim error
Hello everybody,
when I'm compiling my testbench I get the following error:
(vcom-1031) Formal generic "width" has OPEN or no actual associated with it.
I have a project running on ModelSim. I implemented a file reg.vhd that used a generic register size (width). The problem comes with a testbench related to another .vhd file where I did not use any generic thing. When I doubleclick on the error it shows me that it should be in the following part of code:
Mapping: entity one_shot(behav) port map (clock => clock_tb, reset => reset_tb, pulse_o => pulse_o_tb, trigger_i => trigger_tb );Thanks for help, I hope the info is enough.
MelonWars
It's everytime the same: copy & paste error ;) sorry for disturbance
one_shot has a generic called "width" that has no default value, and you havent given it a value when you've instantiated it, hence the error.
