Dear all
I want read some data (power analysis) from MAX II CPLD via JTAG in "Altera EP4SGX230KF40C". How can I read this data?Link Copied
--- Quote Start --- I want read some data (power analysis) from MAX II CPLD via JTAG in "Altera EP4SGX230KF40C".How can I read this data? --- Quote End --- What board are you referring to? The MAX II CPLD is too small to implement the JTAG-to-Avalon-MM bridge (I've tried), so it will most likely be using an SLD_VIRTUAL_JTAG component, which means its access method is totally custom. You'd need to use either a power monitoring GUI supplied by the board vendor, or read whatever code was used to implement the MAX II CPLD. Cheers, Dave
