Modelsim Help
I am learning modelsim and verilog
I have created a module and testbench but in simulation using the command:
vsim -novopt "testbench name"
I keep getting an initial high z input and don't care outputs.
Perhaps it is something in my code?
Original code:
module threeBitCounter ( counterValue, count, reset, clock);
input count; // Increment our counter on rising edge of 'count'
input reset; // Reset our counter on rising edge of 'reset'
input clock; // Synchronize outputs to clock
output reg [2:0] counterValue; // Internally store the counter value
// This takes care of synchronously driving the outputs
always @ ( posedge clock or negedge reset )
begin
if( reset == 1'b0 ) counterValue <= 3'b000;
else if( count ) counterValue <= counterValue + 1'b1;
else counterValue <= counterValue;
end
endmodule
TestBench code:
`timescale 1 ns / 1 ns
module threeBitCounter_testbench;
//define inputs/outputs
wire [2:0] cval;
reg reset;
reg clk;
reg countThisEvent;
threeBitCounter I1 ( cval, countThisEvent, reset, clock);
//set clock
always
# 10 clk = ~clk;
//Exercise the Counter
initial begin
reset = 1'b1; clk = 1'b0; countThisEvent = 1'b0;
# 4 reset = 1'b0;
# 4 reset = 1'b1;
# 7 countThisEvent = 1'b1;
# 20 countThisEvent = 1'b0;
# 20 countThisEvent = 1'b1;
end
endmodule
change to:
threeBitCounter I1 ( cval, countThisEvent, reset, clk);
