Programmable Devices
21615 Discussions
Modelsim error on compiling Avalon BFM turorial
I am trying to understand how to use the Avalanon Verilog BFM models.
I just generated a testbenhc using Qsys as instructed in the Avalanon BFM tutorial.
When I go to run the simulation I get the following single erro near the end of the compile stage.
Any suggestions on how to fix that appreciated.
Thanks Martin
Top level modules:# st_bfm_qsys_tutorial_tb# QuestaSim-64 vlog 10.2c Compiler 2013.07 Jul 18 2013# -- Compiling module test_program
# ** Error: ./test_program.sv(32): Could not find the package (verbosity_pkg). Design read will continue, but expect a cascade of errors after this failure. Furthermore if you experience a vopt-7 error immediately before this error then please check the package names or the library search paths on the command line.# ** Error: /net/tcfiler2.scs.agilent.com/vol/v51/rpdhw/tools/mentor/modeltech/10.2c/questasim/linux_x86_64/vlog failed.# Error in macro /net/tcfiler2.scs.agilent.com/vol/v51/rpdhw/projects/greywolf/mataylor/work/altera-avalon-bfm/ug_avalon_verification/qsys/user_test_program/load_sim.tcl line 12# /net/tcfiler2.scs.agilent.com/vol/v51/rpdhw/tools/mentor/modeltech/10.2c/questasim/linux_x86_64/vlog failed.# while executing# "vlog -sv ./test_program.sv"
Attached is a full transcript.
Martin
Not sure, but I think that's the error you get if you don't follow the directions on page 1-5 of this document:
http://www.altera.com/literature/ug/ug_avalon_verification_ip.pdf
(verbosity_pkg is in a different work library than the rest of your modules)
The Qsys Verification IP Suite zip file (qsys_vip.zip) in this thread:
http://www.alteraforum.com/forum/showthread.php?t=32952&page=3
walks through the simulation of a Qsys system under Quartus 12.1sp1 and 13.1.
Cheers,
Dave
Thanks for the suggestion. I think your link paste is incomplete. I get a 404 error on the link.
Thanks Martin
The requested URL /forum/sho...t=32952&page=3 was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
--- Quote Start ---
--- Quote End ---
I've edited and checked that the link works - try it again.
Cheers,
Dave
The link is now good.
Thank you Martin.
I will digest the info there.
Thanks Martin
--- Quote Start ---
--- Quote End ---
Read the readme.txt file, it discusses the problem you have, and its solution.
Cheers,
Dave
