21615 Discussions
Multiple Statemachines
I have one Main ( FSM ) and from within that i have another enabled from one of the states . But in FSM veiwer i only see the main one and when i try to go inside the embedded FSM , it does not show me anything ?
i am using Quartus 10.0 .
any clues ??
How did you describe the internal FSM?
I'm worried that since you say 'internal' you described it in some strange way that is not recognized by the synthesizer.
Did you check that the first state machine has the number of states that you expect?
Yes,
You should check out your state machine , If possible, you can attach your code , maybe it would be better and fast to solve the problem.
