21602 Discussions
My first experience with altera (MAX 10). And it didn't go well...
Hello everybody.
Finding the right FPGA can be quite a hassle. Especially when one search for a powerful one (read "lots of logic elements, DSP or memory stuff" for pure computing) with a few I/O using TQFP or similar package. In fact, nobody offers such products.
So, it's all about compromises, except for package in my case.
I first tried Lattice stuff with reasonable "little" FPGAs like the ECP2M line, the most powerful with these packages (even if there are in fact small). The 20K elements version could fit in the project I'm working for, but with no real margin. Xilinx have nothing better to offer. But Altera, with the MAX 10 series seems to be even more powerful with the TQFP 144 package (seems to me the only brand offering this kind of product).
So, let's go for the MAX10 10M50SC. Simple, fast enough, versatile, "cheap" with some interesting stuff like DSP slices and, perhaps the integrated flash memory (the main marketing argument as far I can tell) but I don't care about this feature for the moment.
How naive I was.
Two days after digging into the awful documentation, where the obscure mixes with the obvious, I couldn't even know how I can program this thing. Even the very first stage of study is stuck with the lack of relevant information. The 64 pages document "MAX 10 FPGA Configuration User Guide" is a absolute reference of absence of any real usable information. Everything is mixed up; the vocabulary is obscure and it is only a list of what the device can do. Nothing about how to do these things or even understand the overall logic.
When I read terms like "Remote System Upgrade" - perhaps my nonnative English origin mislead me - I think about a way to program the thing using for example a MCU, which is exactly what I wanted to do: sending a .sof file to the CRAM using the JTAG interface. Easy and straightforward, eh? In fact, we learn that we need a soft IP core or a "user interface" to do that. What is that? Why on earth I would need such a machinery to do what seemed to me a trivial task? So, I gave up this promising "Remote System Upgrade" which name is anything but what is seems to be.
Now, after searching, reading, reading, searching for two days, I couldn't even find anything about programming the internal RAM of the chip. Of course, using Quartus and some programming tool does the business, it would be stupid and ridiculous to need exclusively such tools to upgrade this FPGA. Even the other manufacturers like Lattice provides the JTAG instructions and format. Even the smallest micro-controller like the 8051 has the full documentation and timing of the flash memory programming using the JTAG interface (it is just an example, check out the AN105 form silicon labs. That is what I call a relevant document).
Now, I don't care about the flash memory in to FPGA. I only want to upload the CRAM image into the chip with my MPU. I have my flash memory for that with all the different firmwares. How simple and trivial could it be? For Altera, it seems irrelevant.
Even finding how the destination of the image (CRAM or Flash) is chosen is impossible: nothing is said about choosing where the image is programmed except that it is stored in files with different extensions (.sof or .pof). Isn't this an important information? It seems not, because the programming tools knows - and it is the only thing that matters. Have to go to each customer with my laptop, a USB blaster and a license of Quartus, opening the box, plugging the JTAG and upgrade the Firmware? One must be joking.
So, where is the pertinent information: the JTAG instructions for programming the device? Anyone ?
Just an example of the madness of the documentation. Take a look at page 28 of this "MAX 10 FPGA Configuration User Guide". One can see the configuration sequence. Great. Seems clear. Now take a look page 34. This makes no sense at all. On one page, there is a sequence of states to apply to the nSTATUS, CONF_DONE and nCONFIG pins. On the other hand, they are connected as fixed pull-ups. It took me some time to understand that when they write "the xxxx pin is pulled low", they forgot to add "by the FPGA itself" (if I understand correctly – except that nCONFIG is an input… Whatever). This is so badly written that I'm very afraid about the rest. Have I to fight against the documentation to even try to start something? It's not specially an Altera/Intel specificity, I've had similar experience with Microchip or Lattice, but here a new level is reached. It seems to be normal. But I'm very irritated to spend the majority of my development time with external ridiculous causes instead of working on my own stuff.
Other example that erodes the confidence about the documentation: the device pinouts. Any manufacturer offers package drawings with the pinouts. But it seems too old fashion or not "disruptive enough". Each device is described into an unreadable tableau (available on microfilms) with suspect stuff. Of course, there is no footprint or CAD data to integrate into the EDA software (except Cadence). It seems (as I could read somewhere in these forums) that it does not matter because one could create the component within minutes. Seems to me that these people never create libraries for these kind of component.
Where is the VREFB1N0 pin (you know these common mode ouput voltage pins that are NOT explained at all in the handbook) in the 10M40 and 10M50 versions? Is it normal or is there a mistake there? I had to check with Quartus to be sure that, yes, this pin is NOT available in these versions. Why ? I don't know. But, you discover this by luck, like ton of other stuff. Isn't it an important detail ? Why there is no document showing all the differences with each versions of the MAX 10 line (not only the number of logic elements) ?
These are only a few examples of crazy things I got during a few days of documentation reading, but I could add dozens of them. How one can choose so poorly documented parts? Only because it is Intel? Have I to choose a $30000 Stratix 10 to deserve good documentation? Or paying $$$ for technical support on trivial stuff?
No, really, this didn't start well.
And I still don't know how to program this thing.
Jérôme.
Out of curiosity, and I'm going to start with this on purpose, if you started developing for the first time with say an AVR (microcontroller), and wanted to program it, what would be the first thing you do? Personally I would acquire a programmer from the manufacturer, and verify the connections needed to wire it up based on application notes and the datasheet. In your case it seems your first step was to immediately try to engineer from scratch your own JTAG programmer starting at the lowest possible level - something which is inevitably going to lead to a lot of confusion and trouble.
The reason that I started with that is that I am hoping you can see perhaps why your are struggling to start. You've basically come to a new ecosystem - Altera/Intel FPGAs - and then figuratively thrown yourself into the deep end, into a sea of technical literature which has a lot of information with very vendor specific terminology (I do agree it is not in places well written, in fact its terrible in some places) about low level stuff you really don't need to be concerned about when starting out.
My suggestion would be to start with the following steps:
1. Download and install the Quartus II software and the device support files for your FPGA (in this case the MAX 10 device files). This can be a pain in the neck, but you can make it smoother by ensuring you install into the default directory (assuming windows) of c:\altera\... (not in C:\Program Files\...!)
2. If you haven't already, acquire either a development kit for the FPGA family of interest (e.g. https://www.altera.com/products/boards_and_kits/dev-kits/altera/max-10-fpga-development-kit.html) or at the very least a programmer - typically for Altera that is a "USB Blaster II" programmer - Terasic do a clone for only $50 which is a bargin for the amount of time it will save. (*)
3a. If you do get a dev kit, starting off is much simpler. You can just install the driver, and then load "Quartus Programmer" which is a software that allows you to graphically scan the JTAG chain, select the device you wish to program, select the file you wish to program, and select where in the device you wish to program. At this point I will also dispel one of your points - "it would be stupid and ridiculous to need exclusively such tools to upgrade this FPGA" - not at all ridiculous. Every manufacture of any non-generic microcontroller, FPGA, SoC, processor, etc. has their own tools for their own devices. It's a pain I agree but it's not an Altera/Intel specific thing.
3b. If you start with just the programmer and a blank chip, you will need to build a breakout board with the necessary programmer connections. You can find information on the pinout Altera use for "JTAG Programming". For wiring it up, I would recommend using the design files and schematics provided for free with Altera dev kits (and free to download from the Altera site without purchasing a kit) as a starting point for you design. Most of these kits have a MAX II based USB Blaster implementation on them, but will usually also have a JTAG header on board for using a programmer, so you can strip away the MAX II stuff when wiring up your own and go with just the programming header.
4. Look for the code and design samples that come with the dev kits (even if you aren't using it). You can use these projects and their documentation to get started with programming. There is typically some document or other that walks through a "my first project" for a dev kit which you can use as a starting resource.
The biggest problem you will find with any ecosystem for FPGAs is a lack of documentation which can be understood by those new to the ecosystem. You'll find the same problems with Xilinx and Lattice and others. FPGAs have never really found their way into the hobby ecosystem which means that all of the resources and knowledge that get developed either are part of university courses (how I learned), or stay with the companies that use FPGAs and who have invested time and money to decipher what is going on.
(*) Note: Of course you can build such programmers cheaply around a PIC18F14K50 (google will find you the links), but I wouldn't start with that because if it doesn't work you won't find much support for it and you'll be left struggling as to whether it is the FPGA, programmer, or connections that are not working.
Just wondering what the point of this post is? Just a big rant? Why not ask questions to help solve problems?
15 years spent reading documentation for various IP cores from both xilinx and altera (now intel), and I'm very sure that the altera stuff is far better.
The demeanor of your post doesn't particularly invite helpful answers, I'll try a few hints though.
You seem to stumble upon advanced features like Remote Upgrade before you read about the basic device usage.
A blank MAX10 device need to receive it's initial configuration through JTAG interface, and probably 95 percent of MAX10 applications stay with this programming method. (@ TCWORLD: There's no AS programming for MAX10).
A programming adapter directly supported by Quartus is the common way to use the JTAG interface, particularly in the lab. But basically any JTAG adapter or processor "talking" JTAG can configure the MAX10. Either storing a *.pof file in MAX10 flash or write a volatile *.sof image into MAX10 configuration memory.
There are many ways to write data to or read it from MAX10 internal RAM. In most FPGA designs, you'll implement an interface protocol (e.g. SPI) to transfer the data. The RAM content is often initialized in the FPGA configuration, there are also debugging tools like the "In-system memory content editor" manipulating it through JTAG.
I think the original post should be about specific issues. I think the assumption that there are baby-steps per each device from start to end is not fair. And by just having decades of experience in another area related to electronic design doesn't mean you can do fpga overnight. Even ASIC engineers fall into this trap.
If you want to program the FPGA from a MCU, use a CycloneIV in stead of a MAX10 so you don't have to hassle with JTAG. The .rbf file is very easy to send across using the ps configuration mode (page 196 of the cyclone iv device handbook and following).
The MAX10 devices are at their best in true stand-alone deployment, where you use the Altera USB Blaster (or workalikes) to program the device once and then forget about them.
Hello everybody,
I installed Quartus a long time ago and I do perfectly know how to program this with a programmer.
But, at the end, this device aims to be programmed by a MCU because, I have said, it would be stupid to force anybody to have a programmer and a specific hardware for firmware update, especially if there already exists such a mechanism for any MCU on the market (I program mine using a provided bootloader, an embedded http server and a dedicated flash memory). Why FPGA firmware would be once for all defined, especially for a hardware base that is planned to have future features once in the field ?
Now, it is written in the reference document that the CRAM can be programmed directly. That's all I need. I can not believe that writing a simplified programmer only for this purpose is a difficult task. For me, it should be trivial - and I'm pretty sure it is : sending a block of data. If this device is IEEE1352 compliant, this is trivial if the manufacturer provides the instruction format and data. What I can see instead, is that it seems difficult to do a simple programmer because of the lack of documentation (and some sort of reverse engineering), not because it is a difficult task. It is very easy for any modern MCU, why it smells like hell in the FPGA world ? Is it so different ? I don't think so. It is only because the documentation is dire. The example of the application note of silicon labs illustrates this magnificently - and I'm 99.9% sure that the FPGA programming is as easy as programming this venerable 8051 MCU.
I can not use Cyclone or other FPGA, as I said, because of the packages (and they are much more expensive !). The MAX 10 is the only "powerful enough" FPGA in TQFP package. Lattice have something similar but a little too limited. But, it is straightforward to program using SPI interface : it is documented.
I'm sure that some people would say "get the IEEE1532 specifications and write your code !'". It is probably OK, but every single time I had to do this, the time needed to do something that working is absolutely enormous regarding to the actual needed time with the right documentation. Especially because these publications have a very obscure rhetoric style and are too general - they are not well suited for programming documentation. And, of course, I don't want to pay $125 for it.
I've continued to search for information, and I had to read the BSDL files to get a little something (the supported IEEE1532 instructions). This was the only way to get something. I'm sorry, but this is ridiculous. In parallel, I took a look to new AVR MCU (I used to use Microchip). One datasheet. 1700 pages, everything inside. I found my old Intel Databooks from the early 90's. I used to use when I did x86 development and hardware. Thousands of pages with everything inside : pinouts, package drawing,time diagrams for everything, instruction set etc... And it was Intel ! Why Altera is so mediocre in this context (I didn't compare with Xilinx, but saying that the competitor is worse is an incredibly poor argument) ?
But anyway, you get the point (at least I hope).
Nobody tried to program an Altera FPGA with a MCU ? It seems to me incredible. And I'm sure that Altera has the right document somewhere, but where ? If Altera can not -or even worse doesn't want to- provide such generic document, that's it, I'll go for Lattice products. It's a shame because the MAX10 was ideal as a FPGA, but, at least, Lattice has some documentation.
Jerome.
Have you tried to speak directly to Altera via the mysupport portal?
Unfortunately the Max10 only has the JTAG to program it.
Have you seen this page: https://www.altera.com/support/support-resources/download/programming/jam.html
It gives you the necessary source code.
Of course now you can start complaining that the SPI (Lattice) or PS (Altera/Xilinx) is a lot simpler ...
Hello everybody,
Thank you for this, perhaps there is a solution there. I don't mind adapting a JAM STAPL player source code into my MPU... if the source code is OK (the link seems to be very old stuff, late 90's at first glance). Can I have confidence with compatibility especially MAX10 ?
I'm very reluctant to add additional hardware for some sort of "usb-blaster like" device, so why not ? In fact, I saw some stuff about STAPL but the documentation was so bad that I couldn't really understand what is it and what this involves. C source code is so much better. During my research, I didn't find this software section on the website.
Just for "fun", I took a look at the Xinlinx Spartan 6 (I can not use it because of the packages) and the programming documentation. What a difference ! Everything is clear, well explained, SPI or JTAG, whatever. Time diagrams, definitions, schematics (both master ans slave situations). Xilinx doesn't no seems to consider the slave configuration (MPU programming the FPGA) as something alien as Altera seems to do... Even JTAG programming is perfectly described. Shame on you Altera !
I'll take a look at the JAM player idea. If I could get something usable, I would publish all source code and results on PIC32 implementation. I'm pretty sure it would interest some people.
By the way, I could be perceived as a whinger, but I'm only French. Which could explain a lot.
Jerome.
Once more you're comparing apples and oranges and prove that you don't understand the specific features of MAX 10 family with internal flash configuration memory. It has been already suggested to use a "regular" cyclone FPGA with serial configuration interfaces if you want to configure it by an embedded processor.
Using JTAG interface through JAM STAPL player or a similar JTAG driver is possible, but surely not first choice. I'm out.
I would respond you didn't read (or understand) what I've written :
The flash feature (that I've perfectly understood) does not interest me and is not the reason I've chosen the MAX10. The flash memory existence is irrelevant with the lack of documentation for programming the device. I can program the flash or the CRAM in a similar way, it doesn't matter. What are these apples and oranges I compare ?
As I wrote twice, I don't use the Cyclone series because of the available packages (and it is much more expensive). Of course, I would choose this kind of chip if a TQFP version is available, do you think I'm this dumb !? You know, people can choose some stuff for reasons that are not what the marketing decided on the first place. And, to be honest, the MAX10 "specific feature" is risible, I don't see any real added value here. The MAX10 is much more specific (and interesting) because of its package related to the logic elements number than this dull flash feature.
All I search for is a powerful enough FPGA with TQFP package. Only Altea (and perhaps Lattice) has something reasonable. I don't care about whistles and bells, only standard programming and reasonable documentation.
Jerome.
