21611 Discussions
NCO megacore function problem
Hi
i have a problem using the megacore function NCO . I made a model in which i have a NCO which generates a sine. i want this sine to be put out to the D2A_converter1 to display it on a oscilloscope. i can compile the model and program the fpga but there is no sine to be seen! then i noticed that in the board demo model to Stratix II EP2S180 there is file named : pll_clock_pins_add.tcl in which pins are assigned as output pins??
when i copy this file into my project it works and the sine can be seen on the oscilloscope!!!
but what did i do wrong and what can i do right so that this file is automatically generated?
does anyone have an idea?
thanks
In the StratixII EP2S180 board, there is a jumper to select the clock resource for the DAC device. You can select the oscilator, the PLL output clock, and the external clock resouse. I think it is using the PLL output clock in your jumper setting. And this tcl file can make the pin assignment on that location.
Thank you very much for your reply! I try to work with the information you gave me! I post again when I know more.
THX
