21615 Discussions
NIOS II BSP: Problem building the project; No such file or directory
Hi all,
I am trying to build a project. I manually added all the required files(copied) to the project after starting that project. But after every "Build Project" operation it is reporting: xyz.h: no such file or directory.
Please note that I personally added xyz.h file in the project and it is also visible in the Project Explorer.
Please note that I accepted everything default while starting this project. Added .sopcinfo and started project.
What possibly may have gone wrong. I read many similar posts, but the solution provided in then is not working for me.
Best warm regards and Thanks
Tahir
hello TAHIRSENGINE.
how do you write the code?
if you include the file with angle bracket.
# include <xyz.h>
you should change it with double quotation.
# include "xyz.h"
--- Quote Start ---
hello TAHIRSENGINE.
# include <xyz.h>
# include "xyz.h"
--- Quote End ---
I did the same. Problem persists.
Please note that it is not my own code and I am using somebody else code.
did you add the path of xyz.h to the Nios II Application Paths?
(right click the project -> properties-> NiosII application prop.-> NiosII app. path, then put the path to App. include dirs)
Jens
--- Quote Start ---
Jens
--- Quote End ---
Thank for reply.
Do you mean in the BSP project location?
no in the user application project
--- Quote Start ---
--- Quote End ---
Problem seems to be solved. I re-indexed after BSP regeneration and before rebuilding the project.
That solved the problem.
Thank you sir. Appreciated your help.
