Hi All,
I am looking for a Cyclone V SoC in SE series with below specifications:
-Minimum number of FPGA logic elements
-Minimum speed grade of 7
-With no hard PCIe or hard memory controller
-Used for commercial purpose
-Single core
-Package type either FPGA or UBGA whichever has 1mm pitch
-Standard power and Lead-free packaging
The suggested part must be RoHS compliant and regularly available in the market. EoL around 7 years can be helpful. Also, kindly suggest an eval board for the part.
Awaiting your reply. Requesting your response ASAP.
Sorry for the delay, for your request. The suggestion for the above specification is Cyclone® V 5CSEA2 FPGA .
Hope that answers your question.
Nazrul Naim
Hi Nazrul,
Thanks for replying.
Requesting you to provide full part number along with Eval Board availability information.
Hi Nazrul,
Am planning to use 5CSEBA2U23C7SN part in my design. Could you confirm whether the part has sufficient stock, EoL and RoHS Compliance?
For your information, 5CSEBA2U23C7SN is ROHs compliant and the next EOL review will be in 2035.
Nazrul Naim
As we do not receive any response from you on the previous question/reply/answer that we have provided, for now I will set this case to Close-Pending.
Nazrul Naim
