Nios II
help
I implemented a map altera DE2 pocesseur a NIOS II and its peripherals, I used: Qartus II 8.1, SOPC Builder and NIOS II IDE 7.2, but I have a problem when the application sends the NIOS II IDE 7.2 to map altera DE2.
thank you in advance.
Hi, you should use same version of Quartus II and {SOPC Builder+NIOS II}.
I suggest you to use nios version 8.1 (because you already have quartus 8.1 )
NIOS II 7.2 is said as a "transitional" version (I had faced to many bugs).
