21615 Discussions
No Cfi Table Found With Stratix Ii EP2s180
HELP !
Hi all . "
board : Altera Stratix ii EP2S180
FLASH :AM29LV128MH103REI
PROBLEM: 1 (When running )
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: OK
Reading System ID at address 0x02030828: verified
Initializing CPU cache (if present)
OK
Downloading 00000000 ( 0%)
Downloading 00010000 (81%)
Downloaded 79KB in 1.0s (79.0KB/s)
Verifying 00000000 ( 0%)
Verify failed between address 0x0 and 0xFFFF
Leaving target processor paused
2 (When programming flash with flash-program shell)
Resetting and pausing target processor: OK
Reading System ID at address 0x02030828: No CFI table found at address 0x00000000
verified
i see lots of people met those 2 problems,and i see the suggestions some good people say .but it still do not work fine .
At last ,i doubt that the problem must be the address aliginging .
Does anyone have met or know the problem of address aligning between cfi (common flash interface ) and flash when using STRATIX II EP2S180's FLASH AM29LV128MH103REI ?
AM29LV128MH103REI has two mode ,word mode and byte mode .I use byte mode in my design .AM29LV128MH103REI has 16 data I/O pins DQ0~DQ15 .when you use the byte mode , only DQ0-DQ7 are active ,and the DQ15 is used as an input for the LSB (A-1) address function.And the datasheet say addresses are 22:A-1 in byte mode. shoud i connect like this ?cfi_address(0)-A-1 cfi_address(1)-A0.......(RIGHT ?)
BUT ,EP2S180 havenot assign phycal I/0 PINS for DQ15 at all!
how can i resolve it ? thanks for everone !
BEST WISHES!
Have you tried looking at the Appendix of the Nios II Flash Programmer, page 34:
http://www.altera.com/literature/ug/ug_nios2_flash_programmer.pdf#page=34
thank you ,optikalillusion .I have already tried mthods that NIOS II Flash Programmer ,page 34 said .but it still not work.i am sure the physical connection is okey ,so i narrowed the problem to pin assignments.And the most doubtable pin assignment are the flash address pins.
thanks!
BEST WITHES
