Programmable Devices
21595 Diskussionen
No logic elements although I have an output
Geehrter Beitragender II
3.207Aufrufe
Hello
Please guide me why I don't see any logic element for the current code :
LIBRARY ieee;
USE ieee.std_logic_1164.all;
Use ieee.numeric_std.all;
USE work.my_data_types.all; -- to define array of input ( package )
ENTITY test IS
PORT (
clk: in std_logic;
OutResult: out signed(9 downto 0));
end test;
Architecture behave of test is
Signal Im : Array2D:=(("0010000111","0001111110","0001001101","0000000000","0000000000"),
("0001001111","0010000100","0000101100","0000011011","0000000000"),
("0001011101","0010000100","0000100111","0000101001","0000000000"),
("0000000000","0000000000","0000000000","0000000000","0000000000"));
signal Bufftemp:Array2D;
signal Buffsig:signed(9 DOWNTO 0);
begin
Process (clk)
variable i,j:integer range 0 to 7:=0;
begin
if (clk' event and clk='1') then
for j in 0 to 1 loop
for i in 0 to 1 loop
Bufftemp(2*j,2*i+1)<= Im(2*j,2*i+1) - 5;
end loop;
end loop;
end if;
Buffsig<=Bufftemp(i,j);
end process;
OutResult<=Buffsig;
end behave;
26 Antworten
1.768Aufrufe
This will because buffsig is a constant. i and j are always 0 when assigning buffsig. And all buffsig values are assigned from a constant. So hence the design is reduced to a constant driver.
1.768Aufrufe
You misunderstand for loops. The loops are evaluated completely each clock cycle. The code outputs constantly the last array element. No logic cells required.
1.768Aufrufe
Thank you very much Tricky and FvM. I am really appreciate your instant help. I figured out a solution to read one element each clock cycle as listed as I see it best solution
Process (clk)
begin
i:=i+1;
if i=7 then
i:=0;
j:=j+1;
end if;
OutResult<=Buffsig;
end if;
end process;
1.768Aufrufe
I highly suggest reading books or tutorials on using VHDL for digital logic design. Here you have code that doesnt fit with normal templates. It may "work" in hardware as Quartus tends to let you get away with some poor coding styles, but your code will likely appear a but strange in simulation.
1. First of all, I highly suggest you only use signals for the time being, at least until you understand the consequences of using variables on your inferred hardware.
2. You i and j counters are not inside the clocked part of the process, so in simulation they will count on both the rising and falling edges of the clock, which is not possible in real hardware. This is because of the way VHDL works. These should be moved inside the rising edge clock part.
3. While it is not a "bad" thing, do you realise you have a 3 clock latency through the design?
Have you tried to simulate this in a simulator? like modelsim?
1.768Aufrufe
--- Quote Start ---
--- Quote End ---
Dear Moderator ,
I will consider all your points , Actually I read books for Pedroni and Pong about VHDL programming , I know I still have a lot to learn since I unconsciously back to sequential programming I used to utilize. About your notes, I will move the counters , this point I got it clearly.
-- About signals , I will use them and hopefully you guide me to certain book that I can have better understanding.
--Modelsim is not work often with my designs ! I am using Quartus !
Finally about the latency , I am thinking of unnecessary statement of signal assignment , but this will costs 1 clock cycle .. where is the other two?
Dear, I am really appreciate your help and reply , I have designed an algorithm but I know I am unable to implement it well, as a consequence , each note you give will raise the implementation a lot. And I am ready to read any book you suggest
Thanks again.
1.768Aufrufe
The problem I got after removing for statement is that , I have a shared signal which is a 2D array. I assigned values to different cells in each process. But in compilation, Multiple constant assignent error is shown . My question is that , Isn't it possible to assign values to the same array in different processes if the places of assignment are different ?
This is the code if you may...
-- In process 1 :
end if;
-- In process 2 :
Bufftemp(2*j,2*i)<= Im(2*j,2*i) - 5;
end if;
Error : Error (10028): Can't resolve multiple constant drivers for net "Bufftemp[0][0][9]"
1.768Aufrufe
Bufftemp(2*j,2*i+1)<= Im(2*j,2*i+1) - 5; Buffsig<=Bufftemp(i,j); OutResult<=Buffsig;
This is 3 clocks to get from i/j values top the outResult. One clock for each assignment.
--- Quote Start ---
--- Quote End ---
Why not? Maybe there is a problem? isnt that what we are here for?
Quartus only does post synthesis simulation so is very slow and doesnt actually simulate your code, just the compiled version of it. RTL simulation would be much faster when you get to larger designs
Yes, you can assign different elements of an array in different processes IF you are not using a loop.
I suggest looking at the bits in the error.
Or maybe post the whole code so we can help?
1.768Aufrufe
Thank you , This is the code, the 2d image is :
TYPE Array2D IS ARRAY (0 TO 16, 0 TO 16) OF signed(9 DOWNTO 0);
ENTITY AVhdl IS
PORT (
clk: in std_logic;
BuffD_RP1,BuffD_RP0: out vector_array);
end AVhdl;
Architecture behave of AVhdl is
Signal Im : Array2D:=(("0010000111","0001111110","0001001101","0001011011","0001101001","0001101011","0001101001","0001100111","0001101000","0001100000","0001110011","0010000100","0010001111","0010000000","0001100000","0001000100","0000000000"),
("0010000111","0001111010","0001001010","0001011001","0001100110","0001101000","0001110010","0010000001","0001101111","0001011100","0001101001","0010000011","0001111010","0010011000","0001000111","0000010010","0000000000"),
("0001100011","0001110111","0001000110","0001010110","0001011111","0001100001","0001110100","0010011100","0010101100","0001101111","0001100011","0001101001","0001110100","0001100000","0000011001","0000110101","0000000000"),
("0001001100","0001111000","0001000101","0001011000","0001011011","0001100011","0001111000","0010011111","0010110010","0010101111","0001111000","0001010000","0010000001","0000101100","0000100100","0001111100","0000000000"),
("0001010010","0001111100","0001000101","0001100000","0001100000","0001100110","0010000101","0010011000","0010011111","0010100100","0010011111","0010100011","0010100111","0000100101","0001011111","0010001000","0000000000"),
("0001010101","0010000000","0001000100","0001100100","0001110110","0001101001","0001101100","0001011111","0001100000","0010010011","0010101001","0010011100","0001010110","0000110011","0010000110","0010000011","0000000000"),
("0001010110","0001111111","0001000100","0001011001","0001111011","0001010111","0000110001","0000101001","0001110100","0010100100","0010000101","0001010000","0000011011","0001011101","0010001101","0010000011","0000000000"),
("0001010010","0010000000","0001001000","0001011011","0001011100","0000101010","0000100001","0001101100","0001111100","0010011100","0010000010","0000101110","0000100111","0001111101","0010000100","0001111010","0000000000"),
("0001001011","0010000010","0001001110","0001010111","0000111001","0000100100","0001001000","0001111001","0001100001","0010000011","0001010001","0000110000","0001000100","0010000100","0001111100","0010000100","0000000000"),
("0000111010","0010000000","0001010011","0001000000","0000101001","0000111000","0001010000","0001101110","0010001001","0010000011","0001100101","0000110001","0001100011","0001111110","0010000110","0010110000","0000000000"),
("0000111010","0010000100","0001001010","0000111000","0001000100","0001001110","0000101101","0001100111","0001110111","0010000001","0001000001","0000110111","0001111011","0001111000","0010011111","0010111101","0000000000"),
("0000110001","0010001000","0001000001","0000111001","0001011111","0000110010","0000011101","0001001001","0001110011","0001101010","0000011100","0001000011","0001111111","0001110110","0010101110","0010110001","0000000000"),
("0001000011","0010000010","0000110110","0000110001","0001010010","0000110011","0000011010","0000111100","0001110100","0010001101","0001100000","0001000101","0001101101","0001101000","0010100001","0001001100","0000000000"),
("0001010011","0010000010","0000101101","0000100000","0001000000","0001000111","0000100100","0001010001","0001110011","0010001100","0010110010","0001101011","0001110010","0010001110","0001111110","0001000100","0000000000"),
("0001001111","0010000100","0000101100","0000011011","0000110101","0000101011","0000110010","0001100010","0001110011","0001111100","0010101001","0010001111","0001001111","0010001001","0001010100","0000111110","0000000000"),
("0001011101","0010000100","0000100111","0000101001","0000110011","0000101000","0001001111","0001101101","0001110110","0001111000","0010010101","0010011111","0001001110","0001010111","0000111110","0000110110","0000000000"),
("0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000","0000000000"));
signal Bufftemp,Bufftemp1:Array2D;
begin
------ RP0
RP0: Process (clk)
variable temp2,temp1:signed(9 DOWNTO 0);
begin
i:=i+1;
if i>7 then
i:=0;
j:=j+1;
if j=8 then
j:=0;
end if;
end if;
temp1:=Im(2*j,2*i)+Im(2*j,2*i+2);
BuffD_RP0(4*j+i)<=Bufftemp(2*j,2*i+1);
Bufftemp(2*j,2*i)<=Im(2*j,2*i)+ 5;
end if;
end process;
------ RP1---------
RP1: Process (clk)
variable Stemp,Dold,Dnew,temp2,temp1:signed(9 DOWNTO 0);
begin
i:=i+1;
if i>7 then
i:=0;
j:=j+1;
end if;
temp1:=Im(2*j+1,2*i)+Im(2*j+1,2*i+2);
Bufftemp(2*j+1,2*i+1)<= Im(2*j+1,2*i+1) - 5;
Bufftemp(2*j+1,2*i)<=Im(2*j+1,2*i)+ 5;
BuffD_RP1(4*j+i)<=Bufftemp(2*j+1,2*i);
end if;
end process;
end behave;
-- As you see i either use 2i, 2j with +1 or without it. So the same index in not repeated.
1.768Aufrufe
It makes it easier if you use code tags when posting code.
Second, you have a multiple driver error because i/j are not constant, and the compiler does not know that the array elements are not driven from multiple processes. You can only do this if the indeces are constants.
I recommend you drive all elements of an array from a single process (it will be less complicated and error prone anyway).
1.768Aufrufe
Iam driving it in two processes to fill them simultaneously to get more time. If I have to I will split the array to two arrays.
1.768Aufrufe
You cant "get more time"
Remmeber that all processes run simultaneously. All assignments happen in parrellel
I suggest reviewing your VHDL training materials. This is NOT like software programming.
1.768Aufrufe
Is it the pipeline I thought I could make!
I will check it out , I am really thankful to you Mr. And will review my codes.
For Modelsim I will try it out and give you feed back.
Your efforts are highly appreciated.
1.768Aufrufe
You will benefit from Drawing the circuit you expect before writing any code. When writing VHDL you need to understand the circuit you're creating - it is VHSIC Hardware description language. So you need to know what hardware you are describing.
1.768Aufrufe
--- Quote Start ---
--- Quote End ---
Great remark ... I will work by it . Many thanks.
1.768Aufrufe
--- Quote Start ---
--- Quote End ---
The number of logic elements are enormous ! is that because I have the entire image inside logic elements and I didn't utilize any memory ?
1.768Aufrufe
Without the code, I cannot tell. I assume your code is not what you already posted?
Storing an image in logic will be very expensive. You really should use ram.
1.768Aufrufe
--- Quote Start ---
--- Quote End ---
Quartus can infer internal hardware memory (RAM or ROM) from HDL code automatically without an explicit memory block instantiation. But the implemented memory function must be compatible with the properties of FPGA memory blocks. E.g. you can't access more than one respectively two (using the dual port feature) memory addresses within a clock cycle.
Your code in post# 9 is obviously not compatible with the memory inference rules.
Using the Quartus RAM and ROM templates assures that you're designing valid memory code.
1.768Aufrufe
--- Quote Start ---
--- Quote End ---
I changed the code since as you advice me I can not fill same memory in two processes even if I am filling different locations. But I got the bigger problem of logic element localization. The new code is below , One process consumes 109 logic element!
Decompose array is an 8*8 array
LIBRARY ieee;
ENTITY NewD IS
PORT (
clk: in std_logic;
bufftest:out signed(9 DOWNTO 0));
end NewD;
Architecture behave of NewD is
SIGNAL Im: Array2D:=(("0010000111","0001111110","0001001101","0001011011","0001101001","0001101011","0001101001","0001100111","0001101000","0001100000","0001110011","0010000100","0010001111","0010000000","0001100000","0001000100","0000000000"),
signal DRP0sig:DecompArray;
begin
------ RP0
RP0: Process (clk)
variable i:integer range -1 to 8:=-1;
variable j:integer range 0 to 7:=0;
variable cntrr:integer range 0 to 256; -- THIS COUNTER I made to take one output each clock cycle
begin
i:=i+1;
if i>7 then
i:=0;
j:=j+1;
if j=8 then
j:=0;
end if;
end if;
DRP0sig(j,i)<= Im(2*j,2*i+1) - 5;-- to modify the image value
end if;
bufftest<=DRP0sig(cntrr,0); --show the first column of output
end process;
end behave;
1.768Aufrufe
--- Quote Start ---
--- Quote End ---
For no. 9 I will try to read them in buffer one by one. As I think , my code above consumes one each time. I tried to use the memory initialization written below with the code , but I still get the large number of logic element along with the memory. But I don't know if the large number because the input is not a RAM or because I am trying to output all the values mistakenly ?
BTW I am reading and revising your notes many times even after I reply to you.
This is the initialization M4K I used , if you have any notes to advice me ..
TYPE memory IS ARRAY (0 to 1023) OF STD_LOGIC_VECTOR(7 DOWNTO 0);
SIGNAL myram: memory;
ATTRIBUTE ram_init_file: STRING;
ATTRIBUTE ramstyle: STRING;
ATTRIBUTE ramstyle OF myram: SIGNAL IS "M4K";
1.686Aufrufe
Initially, you may do better using the mega wizard to generate the ram, then you know for sure that a ram will be used. Infered ram has to match the correct behavioural template to be correctly inferred, otherwise logic will be inferred.
Review this document for coding styles:
https://people.ece.cornell.edu/land/courses/ece5760/de1_soc/hdl_style_qts_qii51007.pdf
Antworten
