Programmable Devices
21608 Discussions
None sender data in recvfrom
I've implemented a UDP server based on Iniche stack and uCOS.
It's work whitout problem:), I can receive data from a UDP client on remote PC but....but there is something stranges.:cry:
recvfrom has 6 parameters:
int recvfrom(int sd, void* buf, int n, int flags,
struct sockaddr* from, socklen_t *len);
in "from" data structure I should have the sender IP, but this structure is filled to zero.:eek:
I've experience with Linux and in Linux I can get data sender from this structure.
Where is my error?:confused:
