21613 Discussions
Not able to convert the Agilex *.sof file to *.pof file for QSPI flash in Avalon-ST configuration
Vijay_shanmugam
PFL II IP will configure the Agilex using Avalon-ST configuration schemes.
PFL II IP connects with QSPI flash.
Here we are not able to convert the Agilex *.sof file to *.pof file for QSPI flash in Avalon-ST configuration schemes.
We are facing below error,
"Intel® Agilex™ Configuration User Guide" has only CFI flash conversion information and does not have for QSPI flash.
So,  need a procedure to convert the Agilex *.sof file to *.pof file for QSPI flash in Avalon-ST configuration schemes.
Note: Intel Quartus Prime Pro 21.4
Vijay
sstrell
You're using the wrong tool to convert.  Go to File menu -> Convert Programming Files.
Vijay_shanmugam
I am using Avalon-st x8 configuration method, so cannot use "convert Programming Files" options. Configuration userguide suggest to use "Programming file Generation" options
YuanLi_S_Intel
hi, since you are using 2gb qspi flash. Can you try to select CFI2GB and test on it?
Vijay_shanmugam
Thanks Yuanli.
If i changed to CFI2GB flash then i am able to generate the *.POF.
Please provide the steps to convert the Agilex *.sof file to *.pof file for QSPI flash in Avalon-ST configuration(x8) schemes.
Vijay
YuanLi_S_Intel
Choosing CFI2GB is the steps. Please try on it.
Vijay_shanmugam
Thanks for your reply Yuanli. I will try this and update the result.
