21602 Discussions
Not correctly read silicon ID from the EPCS64.
Hi.
For access with EPCS64 from Cyclone IV I use IP-core ALTASMI_PARALLEL.
When I read silicon ID from the EPCS64, epcs_id[7..0] = 0x0B (0000.1011), but should be 0x16 (0001.0110).
The clock frequency of ALTASMI_PARALLEL - 20 MHz.
I brought on SignalTap epcs_id[7..0] and read_dout_reg[7..0] (the shift register of the ALTASMI_PARALLEL).
After reading the silicon ID on Signal Tap epcs_id[7..0] = 0x0B, read_dout_reg[7..0] = 0x16.
There is an assumption that the value on the bus epcs_id[7..0] is latched on the 1 cycle before.
Has anyone such a problem?
skat_for
Hi.
I work with EPCS1SI8.
When I read silicon ID from the EPCS1SI8 marking=Zb28x, epcs_id[7..0] = 0x04 (0000.0100), but should be 0x10 (0001.0000).
When I read silicon ID from the EPCS1SI8 marking=9802X, epcs_id[7..0] = 0x19 (0001.1001), but should be 0x10 (0001.0000).
Is the code identical,what is the reason?
Подаю команду command [7..0]= 0xF9 (1111.1001).
Code:
uint8_t data=0xF9;
PINS_HIGH(micra.DCLK);
PINS_LOW(micra.nCS); //green
//////////////////////////////////////////////////////////////////Write comand
for( uint8_t i = 0; i < 8; ++i)
PINS_LOW(micra.DCLK);
(data & 1 ) ? PINS_HIGH(micra.ASDI) : PINS_LOW(micra.ASDI);
data >>= 1;
delay_nop(1);
PINS_HIGH(micra.ASDI);
//////////////////////////////////////////////////////////////////data - read
for(uint16_t i = 0; i < 8; ++i)
PINS_HIGH(micra.DCLK); //YELOU
a = READS_PIN(micra.DATA);
data_out|=(a << i);
PINS_LOW(micra.DCLK); //YELOU
delay_nop(1);
PINS_HIGH(micra.nCS);
