21607 Discussions
Cyclone V PCIe/DMA issues
Seadog
I have a Cyclone V design with the the V-Series Avalon-MM DMA for PCI Express (yeah, I know it's been obsoleted, tell my S/W colleagues that).  I did the first build with QPS 17.1; there have been other issues, which I have worked around.  But now I see failures in simulation of Read DMA operations (from system memory to local memory); the failures include both corrupted address and weird Avalon-MM protocol behavior, both from the local memory avalon master interface from the PCIe/DMA core.
I tried again, using QPS 19.1.  In this case, the design would not load into the simulator, due to missing modules.
Is this macro a dead end?  Thanks.
Failure details are in the attachment.
Environment: Windows 10, ModelSim DE64 V. 10.7a
SengKok_L_Intel
The Cyclone V PCIe AVMM DMA IP is not available in v19.1std, so you might not able to run the simulation in v19.1std
I'm using the example design (pcie_de_ep_dma_g2x4_cv.qsys) in the link below to generate the simulation testbench in v18.0std (v17.1std is not installed here), and it is passing the simulation.
\ip\altera\altera_pcie\altera_pcie_hip_256_avmm\example_design\cv
Perhaps we can start the debug with this example design to determine if the same problem can also be observed before jump into the detail of your design.
Regards -SK
SengKok_L_Intel
If further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
