Programmable Devices
21605 Discussions
Odd behavior when Master reads from two different data width memories!
I have an Avalon master with 256 bit data bus width which is interfaced to two slave memory components:
1. Memory 1 - 256 bit data bus width Avalon slave
2. Memory 2 - 32 bit data bus width Avalon slave - Look up table (initialized to mem(A) = A)
For the first component, all read / writes are correct
For the look up table (LUT), the designated addresses coming out and seen on the avm0_address are correct, location = low byte / 4
avm0_address: 0x040400CC , 0x040403D4, 0x0404006E4, 0x040409EC ..... (Correct)
location (hex) : 33, F5, 1B9, 27B ..... (Correct)
problem1
The address seen entering the LUT is wrong :confused:
LUT addr (hex): 32, F6, 1BF, 278 ..... (Random but close)
problem2
Since the LUT is initialized such that each location has the a data equal to its corresponding address, the data read from memory is equal to above!
yet the data on the avm0_read master is doesn't also match:
avm0_address(hex): 700, 700, 700, 700, 278
Hope you can help.
refer to the avalon specification of the masters and slaves of different bus sizes, I guess u could find useful articles there. since the data bus width of ur master is bigger than the slave, it probably does read or write actions on consequtive addresses for a signle read/write istruction . This part of the avalon protocol is quite confusing!!I once had similar problems.
Well I did, and I do quite understand it very well .. but the problem here is why once the correct address is issued on avm0_address .. it slightly changes once it reaches the slave, observe that the same address reaches the slave but with +/- some value .. that's the address is close but not exact .. that's what confuses me :eek:
