21611 Discussions
Out of memory error
following is the error i'm getting when i run fitter.
"Out of memory in module quartus_fit (2147 megabytes used) while running 32-bit Quartus II 32-bit on a 64-bit OS platform. Please use the 64-bit Quartus II 32-bit to increase memory capacity.
[mohat3@north phy1]$ "
I've attached a screenshot of it too.,
COULD anyone tell me if it is because of the processor (data width) or the RAM, I am asking this cause I am able to run it successfully sometimes but not always.
It's kinda urgent PLZ help.
Why not try reading the error? you need the 64-bit edition of quartus.
@TRICKY
ofcourse i understand the msg.,
but my question is why is it that i'm not getting this error always. I am using the same file the same constraints and the qsf too.,
if it was a processor related error then it shouldnt be ever possible to run it right?
if you dont have the minimum required memory available (3GB for larger Arria2 and smaller Stratix4, and more for larger devices) you just have to cross your fingers.
I am targetting it to a stratix 5 device., i have to meet around 220MHZ for the design., so wat is the minimum RAM space i need to have??
and if i can add more ram to the system then can i continue using the 32bit version??
No you will need a 64-bit OS if you want to use more than 3Gb of memory. What Stratix5 device are you targetting? The bigger the device the more RAM you need.
ok thank you :)
I am targetting it to 5SGXEA7 series,
32-bit Quartus 2 can only access 4gb of ram, regardless of how much there is available.
IIRC, the larger Stratix 5 devices need 12GB of ram mimum.
ok thanks a lot :)
you can find RAM requirements here:
http://www.altera.com/literature/lit-qts.jsp
in:
Quartus II Software version 11.1 SP 1 Device Support Release Notes
Remember that everything in your PC is memory mapped. So with a 32-bit OS it has a total of 4GB to work with. All the little controllers on the motherboard, registers of your drives, PCI/PCIe cards including graphics, etc... all get placed in that 4GB address space. So to compile for large FPGAs you need a substantial amount of memory and a 64-bit OS (and 64-bit processor) to make sure it's addressable.
You are probably on the hairy edge of running out of addressable memory when the compile does complete. For a Stratix V design you are going nowhere using a 32-bit OS in my opinion.
