Programmable Devices
21602 Discussions
PAL replacement
I want to replace Lattice GAL16V8D (PALCE16V8Q-25JC4, outputs are not registered) and the TI 16VR8D/2JC(registered outputs) with Atmel's ATF16V8D. Please anybody let me know if this works or any replacement?
Awaiting for the help.
Thank you,
Deepika
You should ask on an Atmel forum, this one is about Altera components.
Though someone can suggest with any Altera's alternate part right.. That's what i expected.
Anyways sorry and thank you.
There's no Altera part similar to GAL/PALCE16V8. For low complexity PLDs, MAX3000A series is still the first choice. It's a 3.3V device with 5V tolerant inputs. Higher complexity PLD is MAX II/MAX V, without 5V tolerance.
