- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
i used a pll in EP3C40F484, the pll had two clock input pins and a switch input pin. in my logic, i used switch input to select the input clock (inclk0 or inclk1), however, when i changed switch signal, for example, from 0 to 1, and then gave pll a reset, the pll could not lock again, i saw that the locked output was always 0 in signalTap. did i miss something? thanks for any answer. regards, ingdxdyLink copiado
4 Respostas
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Do You use PLL core clock switch option or You just have a mux, which select a clock before PLL input?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi, Socrates,
i used PLL core clock switch to select the pll clock input, when i dynamically switch the PLL input, it just could not relock again. regards, ingdxdy --- Quote Start --- Do You use PLL core clock switch option or You just have a mux, which select a clock before PLL input? --- Quote End ---- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Then read the documentation carefully. Afaik it doesn't switch on switch state change - You need to do a pulse for switching. 0->1 and 1->0.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi, Socrates,
Sorry for my carelessness and thanks much for your help.:) regards, ingdxdy --- Quote Start --- Then read the documentation carefully. Afaik it doesn't switch on switch state change - You need to do a pulse for switching. 0->1 and 1->0. --- Quote End ---
Responder
Opções do tópico
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
