21615 Discussions
PLL config error of problem
Good afternoon every body
near I creat a new project , my project need use two groups PLL ,
(My use chip - CyclonII EP2C35FC8)
and I reference the pin config ↓
(http://www.altera.com/literature/dp/cyclone2/ep2c35.pdf
So first PLL input config , I use pin_n2 (50MHZ Input) ,
also two output : 100MHZ & 100MHZ -65°deg .
And second PLL input config , I use pin_p26 (125MHZ input)
also three output : 125MHZ 0°deg & 125MHZ 90°deg & 125MHZ 180°deg .
To here my compilation haven't not problem .
Because my hardware require , So I need change config of second PLL pin ,
but , when I change second PLL input config ,
pin_p26 replaced by pin_p1 or pin_p2 and compilation .
The QuartusII will tell me :
Error: Can't place PLL "Enth:Enth_inst|pll_0:the_pll_0|altpll:sd1|pll" in target device due to device constraints
Error: Can't place PLL "Enth:Enth_inst|pll_0:the_pll_0|altpll:sd1|pll" in PLL location PLL_1 because location is already occupied by node "Enth:Enth_inst|enet_rx_clk_pll:the_enet_rx_clk_pll|altpll:sd1|pll"
Error: Can't place PLL "Enth:Enth_inst|pll_0:the_pll_0|altpll:sd1|pll" in PLL location PLL_2 due to device constraints
Error: Can't place PLL "Enth:Enth_inst|pll_0:the_pll_0|altpll:sd1|pll" in PLL location PLL_2 because I/O cell "iCLK_50" cannot be placed in I/O pin Pin_P26 (port type INCLK of the PLL)
Error: Can't place I/O cell "iCLK_50" in I/O pin location Pin_P26 because it is already placed in I/O pin Pin_N2
Error: Can't place PLL "Enth:Enth_inst|pll_0:the_pll_0|altpll:sd1|pll" in PLL location PLL_2 because I/O cell "iCLK_50" cannot be placed in I/O pin Pin_P25 (port type INCLK of the PLL)
Error: Can't place I/O cell "iCLK_50" in I/O pin location Pin_P25 because it is already placed in I/O pin Pin_N2
Error: Can't place PLL "Enth:Enth_inst|pll_0:the_pll_0|altpll:sd1|pll" in PLL location PLL_2 because I/O cell "iCLK_50" cannot be placed in I/O pin Pin_N26 (port type INCLK of the PLL)
Error: Can't place I/O cell "iCLK_50" in I/O pin location Pin_N26 because it is already placed in I/O pin Pin_N2
Error: Can't place PLL "Enth:Enth_inst|pll_0:the_pll_0|altpll:sd1|pll" in PLL location PLL_2 because I/O cell "iCLK_50" cannot be placed in I/O pin Pin_N25 (port type INCLK of the PLL)
Error: Can't place I/O cell "iCLK_50" in I/O pin location Pin_N25 because it is already placed in I/O pin Pin_N2
Error: Can't place PLL "Enth:Enth_inst|pll_0:the_pll_0|altpll:sd1|pll" in PLL location PLL_3 due to device constraints
Error: Can't place PLL "Enth:Enth_inst|pll_0:the_pll_0|altpll:sd1|pll" in PLL location PLL_3 because I/O cell "iCLK_50" cannot be placed in I/O pin Pin_B13 (port type INCLK of the PLL)
Error: Can't place I/O cell "iCLK_50" in I/O pin location Pin_B13 because it is already placed in I/O pin Pin_N2
Error: Can't place PLL "Enth:Enth_inst|pll_0:the_pll_0|altpll:sd1|pll" in PLL location PLL_3 because I/O cell "iCLK_50" cannot be placed in I/O pin Pin_A13 (port type INCLK of the PLL)
Error: Can't place I/O cell "iCLK_50" in I/O pin location Pin_A13 because it is already placed in I/O pin Pin_N2
Error: Can't place PLL "Enth:Enth_inst|pll_0:the_pll_0|altpll:sd1|pll" in PLL location PLL_3 because I/O cell "iCLK_50" cannot be placed in I/O pin Pin_C13 (port type INCLK of the PLL)
Error: Can't place I/O cell "iCLK_50" in I/O pin location Pin_C13 because it is already placed in I/O pin Pin_N2
Error: Can't place PLL "Enth:Enth_inst|pll_0:the_pll_0|altpll:sd1|pll" in PLL location PLL_3 because I/O cell "iCLK_50" cannot be placed in I/O pin Pin_D13 (port type INCLK of the PLL)
Error: Can't place I/O cell "iCLK_50" in I/O pin location Pin_D13 because it is already placed in I/O pin Pin_N2
Error: Can't place PLL "Enth:Enth_inst|pll_0:the_pll_0|altpll:sd1|pll" in PLL location PLL_4 due to device constraints
Error: Can't place PLL "Enth:Enth_inst|pll_0:the_pll_0|altpll:sd1|pll" in PLL location PLL_4 because I/O cell "iCLK_50" cannot be placed in I/O pin Pin_AC13 (port type INCLK of the PLL)
Error: Can't place I/O cell "iCLK_50" in I/O pin location Pin_AC13 because it is already placed in I/O pin Pin_N2
Error: Can't place PLL "Enth:Enth_inst|pll_0:the_pll_0|altpll:sd1|pll" in PLL location PLL_4 because I/O cell "iCLK_50" cannot be placed in I/O pin Pin_AD13 (port type INCLK of the PLL)
Error: Can't place I/O cell "iCLK_50" in I/O pin location Pin_AD13 because it is already placed in I/O pin Pin_N2
Error: Can't place PLL "Enth:Enth_inst|pll_0:the_pll_0|altpll:sd1|pll" in PLL location PLL_4 because I/O cell "iCLK_50" cannot be placed in I/O pin Pin_AF14 (port type INCLK of the PLL)
Error: Can't place I/O cell "iCLK_50" in I/O pin location Pin_AF14 because it is already placed in I/O pin Pin_N2
Error: Can't place PLL "Enth:Enth_inst|pll_0:the_pll_0|altpll:sd1|pll" in PLL location PLL_4 because I/O cell "iCLK_50" cannot be placed in I/O pin Pin_AE14 (port type INCLK of the PLL)
Error: Can't place I/O cell "iCLK_50" in I/O pin location Pin_AE14 because it is already placed in I/O pin Pin_N2
I don't know understand ... pin_p1 or pin_p2 are clk_input
what can't use pin_p26 replaced by pin_p1 or pin_p2 ...
