21615 Discussions
PLL dedicated external clock output pins in cyclone II EP2C20F484c7 FPGA
hi all,
I am using Cyclone II FPGA Starter Development Board which contains cyclone ii ep2c20f484c7 FPGA to drive 800*480 color LCD. For external interface with LCD, i am using the two 40 pin expansion headers. I am not using the on board VGA video port.
LCD requires a clock input of 33 MHz from FPGA. So, i require an external clock output from FPGA. I am using ALTPLL megafunction to generate this. However, while compilation, it shows a warning that use pll dedicated external clock output pins, otherwise skew performance is not guaranteed. How can i select this option in ALTPLL megafunction which has three clocks c0,c1,c2. In schematics of board, it shows that PLL dedicated external clock pins are differential and i need a single ended 3.3V LVTTL compatible clock. How can i do this?
thanks in advance,
praveen
You should use the pin that is connected to LCD clock input, if it's dedicated clock output or not. If it's a dedicated clock output, it can be used also with single ended IO standard.
Actually, ALTPLL megafunction is having c0,c1,c2 as PLL clock outputs for cyclone II EP2c20F484c7. The dedicated PLL clock output pins are (PLL1_OUTp, PLL1_OUTn), (PLL2_OUTp, PLL2_OUTn), (PLL3_OUTp, PLL3_OUTn), (PLL4_OUTp, PLL4_OUTn) (differential output).
I have access only to the two 40 pin expansion headers(which connects 72 FPGA pins) since it is a starter board. (PLL2_OUTp, PLL2_OUTn) pins are connected to one of the expansion headers. So, i tried to assign PLL2_OUTp pin to PLL clock output c2 since i need only single ended o/p & c2 is the clock output which drives the external clock o/p. Still, the same warning comes while compilation
warning: pll "pll:u3|altpll:altpll_component|pll" output port clk[0] feeds output pin "c2" via non-dedicated routing -- jitter performance depends on switching rate of other design elements. use pll dedicated clock outputs to ensure jitter performance
Please give your suggestions on this.
With Cyclone II, PLL2 could be only used when clocked by a connected dedicated clock. I think, no clock is connected to PLL2 dedicated inputs with the starter board. If I'm right, PLL2 clock output couldn't be used. But I wouldn't overrate the said warning. The clock is usable with defined timing anyway.
