21602 Discussions
PLL error in BeMicro Max10 FPGA Evaluation Board
Hi All,
I use BeMicro Max10 FPGA Evaluation Board. I need to verify the inbuilt ADC inside Max10. But I got following warning and error regarding the Avalon ALTPLL
connected to the ADC.
Warning (15058): PLL "max_adc:max_adc_inst|max_adc_adc_pll:adc_pll|max_adc_adc_pll_altpll_5q22:sd1|pll7" is in normal or source synchronous mode with output clock "compensate_clock" set to clk[0] that is not fully compensated because it feeds an output pin -- only PLLs in zero delay buffer mode can fully compensate output pins
Error (170084): Can't route signal "max_adc:max_adc_inst|max_adc_adc_pll:adc_pll|max_adc_adc_pll_altpll_5q22:sd1|wire_pll7_clk[0]" to atom "max_adc:max_adc_inst|max_adc_modular_adc_0:modular_adc_0|altera_modular_adc_control:control_internal|fiftyfivenm_adcblock_top_wrapper:adc_inst|fiftyfivenm_adcblock_primitive_wrapper:adcblock_instance|primitive_instance"
Musthafa
i'm chiming in here with the same issue. Please let me know if you solved it!
Best,
K
SNigg1
Not helpfull since link is not working anymore
