21611 Discussions
PLL for clock scaling.
as a newbie I'd like to ask you for some understanding and patience. Was not sure where this question should be posted, so please move it/tell me to move it if you find appropriate.
I want to build a simple UART on my FPGA. I've been told to try to use a PLL for prescaled clock for my design. However, I am not sure how do I make it work.
I have generated a PLL with desired frequency output clock, but now I am not sure where should I put it in my design. Should I enclose it together with my uart to make a top-level entity? Or should I assign it somewhere/use it's output in some assignment to connect it to my uart-entity's clock?
I use Quartus II Web Edition trying to synthesise design for Cyclone V.
Thank you for any tips.
Kuba
You can directly connect the PLL output clock to your module at top level RTL.
Alright, I created another top-level entity enclosing the generated PLL entity and my own receiver. It appears to make sense now (please tell me if this is incorrect.)
Thanks!
