Programmable Devices
21600 Discussions
Part Inquiry
Johanna-Irving
I am looking for information on two parts. Is Intel the manufacturer? If so what is your CAGE code? I am showing 4BA62, is that correct?
EP4CE30F23I7 - IC, FPGA, FBGA
EPCQ128ASI16N - IC, SERIAL CONFIG DEVICE, 128Mbit, 3.3V
Also, I need spec/data sheets for each part, please forward them to me at <email removed>
Thank You!
Fakhrul
Hi Johanna-Irving,
To answer your question, yes, and the code for Intel Corporation is 4BA62.
As a reference, you can refer to https://www.sam.gov/SAM/, select the search option, and type Intel Corporation. You may download the datasheets as follows:
EP4CE30F23I7 Datasheet:
Cyclone IV Device Handbook, Volume 3
EPCQ128ASI16N Datasheet:
EPCQ-A Serial Configuration Device Datasheet
Fakhrul
Fakhrul
As we haven't received a response to our previous notification, this thread will be transitioned to community support. We hope all your concerns have been addressed. If you have any new questions, please feel free to open a new thread to receive support from Intel experts. Otherwise, community users will continue to assist you here. Thank you.
Johanna-Irving
Hi Fakhrul,
Thanks for getting back to me. The one spec sheet is great, but EP4CE30F23I7 is showing Altera on it, and I also am not seeing how to generate the PN from the document. If Intel is the manufacturer I need something stating that, or if Altera is part of Intel that would work. Also, how do we generate part EP4CE30F23I7 from the root EP4CE30 drawing. Thanks so much!
