Programmable Devices
21615 Discussions
Passing Structures into Functions
Hi Guys,
question
I need some clarification on passing structures into functions.
in what i'll outline below, i don't understand why the function prototypes are as they are.
This is how i understand it, but if i say something wrong please correct me.
example that confuses me
What i've got is the Niche stack with the below structure.
typedef struct SSS_SOCKET { enum { READY, COMPLETE, CLOSE } state; int fd; int close; INT8U rx_buffer; INT8U *rx_rd_pos; /* position we've read up to */ INT8U *rx_wr_pos; /* position we've written up to */ } SSSConn;
This says to me "define a structure type SSS_Socket, and create an instance called SSSConn.".
Now functions that use this have their prototypes as:
void SSS_handle_receive(SSSConn* conn)
and function call appears as:
SSS_handle_receive(&conn)
What i don't understand is why is an instance of a structure being used instead of the type itself i would have thought a prototype would be:
void SSS_handle_receive(SSS_SOCKET* conn)
can someone please explain whats happening here?
There is a typedef at the very beginning of the code making SSSConn visible as a type (alias 'struct SSS_SOCKET').
If you reformat the source a bit it becomes beter visible
Most often we first see the declaration of the structure, followed by the typedef statement.
struct SSS_SOCKET { enum { READY, COMPLETE, CLOSE } state; int fd; int close; INT8U rx_buffer; INT8U *rx_rd_pos; /* position we've read up to */ INT8U *rx_wr_pos; /* position we've written up to */ } ; typedef struct SSS_SOCKET SSSConn ;
The first code snippet does the two in one go.
Thank you very much, i now understand except for one thing,
would this mean, that no instance is created by this code?
You are correct, both forms only create a 'type'. You can exemplify this by slightly changing the first form into
typedef struct { enum { READY, COMPLETE, CLOSE } state; int fd; int close; INT8U rx_buffer; INT8U *rx_rd_pos; /* position we've read up to */ INT8U *rx_wr_pos; /* position we've written up to */ } SSSConn;
You see that you can leave out the ' SSS_SOCKET' tag.
Only when you instantiate a 'type' actual storage will be allocated. e.g.:
SSSConn master , slaves ; will actually reserve storage.
Thanks to you both. I appreciate it.
