Programmable Devices
21611 Discussions
Passive Serial & Fast Passive Parallel Configuration for Cyclone IV
Can any one guide me to get the 'C' Source code to perform a PS and FPP configuration for my Cyclone 4 device. I am using a freescale processor & an external flash memory.
Basically I am looking for source code that the microprocessor can execute to configure the FPGA device via PS ot FPP configuration. Also I would need the configuration source code to configure via JTAG interface.
Thanks a lot in advance !!!
Sunil.
Some info for you if you want to configure via JTAG interface
https://www.altera.com/download/legacy/jam/dnl-8051_player.jsp
Thanks for your reponse. But, I am looking for the C Source code which does the FPGA configuration using the host proecessor !
Sunil
I did this recently for cyclone iii so I will outline the steps. This is for parallel loading scheme.
- Convert SOF into a TTF and RBF and select the programming mode. TTF is a comma separated value text file. RBF is a raw binary file. I used rbf becuase it smaller file size and easier to work with in C/C++.
- DRIVE DCLK LOW
- DRIVE NCONFIG HIGH
- DRIVE NCONFIG LOW
- Sleep 1 ms (Delay to allow NSTATUS to pull high)
- CONF_DONE should be LOW and NSTATUS shoud be high
- For each byte in the rbf file, drive data to fpga data config inputs and pulse DCLK hi
- While loading CONF_DONE should remain low / NSTATUS should remain high
- After all bytes are loaded pulse DCLK a few extra times (read data book on device for specific extra clocking requirements ).
- To verify config if complete/success verify CONF_DONE is high and NSTATUS is high.
- Optionally cpu can monitor the NSTATUS pin for errors (Goes LOW), however it can be ignored util the end of loading the entire file to the part.
Hi kito,
Thanks for your response. I will try it out.
Sunil
Hi Kito,
Have you ever done this with an SOF and an ELF?
