Programmable Devices
21603 Discussions
Pausing target processor not responding in stratix 2
Hi all,
Im a new user in FPGA board. Currently i have a problem regarding my project. I able to generate and download my .sof file into my fpga board without any error. Then i also manage to build a nios-ide project template, "small hello world" without any error but the problem occurs when i run the program in hardware the following message appear on th nios-ide console window.
" Using cable "USB-Blaster [USB 6-1.1]", device 1, instance 0x00
Pausing target processor: not responding.
Resetting and trying again: FAILED
Leaving target processor paused "
These are the following hardware, software and nios 2 system that i had included in my project:
Hardware and Software:
1) OS: linux-ubuntu 9.04
2) Quartus II version 9.0 SJ full version
3) Nios II Integrated Development Environment Version: 9.0
4) Stratix II, EP2S60F672C3
Nios 2 system's peripheral
1) cpu (**clock setting= ddr_sdram_sysclk=100Mhz)
2) DDR SDRAM ,(Micron Mt46v16m16tg-6t), 16 bits wide, discrete device, CAS 3.0, 1 chip select. (**clock setting= clk=50Mhz)
3) high_res_timer - (timeout period =10us..counter size=64 bits.. full featured) (**clock setting= ddr_sdram_sysclk=100Mhz)
4) sysid (**clock setting= ddr_sdram_sysclk=100Mhz)
5) jtag_uart (read and write FIFO .buffer depth=64 bytes)
I been trying to solve this problem for 3 weeks. I tried using Quartus 8.0, another stratix 2 board and different PC but i get the same error message. I will be very thankfull if any one of you guy manage to solve my problem.. Thank you.... :)
Very first check the following two things.
1) CPU clock is working or not
2) Reset pin not active all the time.
The CPU clock is working and the reset pin is set to pin_aa15. The design is working when i use "on chip memory" but i have that error when i add DDR SDRAM.
have you tried with design example provided by altera for Nios II development kit for 2S60 board ?
You can get ready made system from <Nios installation dir>\examples\verilog
Try simple c program with DDR as program memory using this system.
Yes Hardik, I am running the design example "small Hello World" provided by altera for Nios II development kit for 2S60 board.... :) Hardik i manage to figure out the problem.
Here how it goes, previously i mentioned that i can run the program using "on chip memory" and the problem occurs when i add DDR SDRAM. So it seems like i have problem with my DDR SDRAM. I figure out that my problem is caused by my top level module which i wrongly assign one of the signal, "global_reset_n_to_the_ddr_sdram". i had include my top level module for your view.....but i need some explaination based on this problem ?? All the best for all beginers like me... :)
module system(
// 1) global signals:
clk, reset_n,
// the_ddr_sdram_0
ddr_a, ddr_ba, ddr_cas_n, ddr_cke, clk_to_sdram_n, clk_to_sdram, ddr_cs_n, ddr_dm, ddr_dq, ddr_dqs, ddr_ras_n, ddr_we_n );
input clk; input reset_n;
// DDR SDRAM
// i/o signal
output [12: 0] ddr_a; output [ 1: 0] ddr_ba; output [ 1: 0] ddr_cas_n; output [ 1: 0] ddr_cke; inout [ 1: 0] clk_to_sdram_n; inout [ 1: 0] clk_to_sdram; output [ 1: 0] ddr_cs_n; output [ 1: 0] ddr_dm; inout [15: 0] ddr_dq; inout [ 1: 0 ] ddr_dqs; output [ 1: 0 ] ddr_ras_n; output [ 1: 0 ] ddr_we_n;
//wires wire
ddr_sdram_aux_full_rate_clk_out; wire ddr_sdram_aux_half_rate_clk_out; wire ddr_sdram_phy_clk_out; wire dll_reference_clk_from_the_ddr_sdram; wire [ 5: 0] dqs_delay_ctrl_export_from_the_ddr_sdram; wire local_init_done_from_the_ddr_sdram; wire local_refresh_ack_from_the_ddr_sdram; wire local_wdata_req_from_the_ddr_sdram; wire reset_phy_clk_n_from_the_ddr_sdram; wire global_reset_n_to_the_ddr_sdram;
system_file the_system_file
( //global signals:
.clk (clk), .reset_n (reset_n),
//DDR SDRAM
//wires
.ddr_sdram_aux_full_rate_clk_out (ddr_sdram_aux_full_rate_clk_out), .ddr_sdram_aux_half_rate_clk_out (ddr_sdram_aux_half_rate_clk_out), .ddr_sdram_phy_clk_out (ddr_sdram_phy_clk_out), .dll_reference_clk_from_the_ddr_sdram (dll_reference_clk_from_the_ddr_sdram), .dqs_delay_ctrl_export_from_the_ddr_sdram (dqs_delay_ctrl_export_from_the_ddr_sdram),
//HERE IS THE CHANGES THAT I HAD MADE
// .global_reset_n_to_the_ddr_sdram (global_reset_n_to_the_ddr_sdram),
.global_reset_n_to_the_ddr_sdram (reset_n),
.local_init_done_from_the_ddr_sdram (local_init_done_from_the_ddr_sdram), .local_refresh_ack_from_the_ddr_sdram (local_refresh_ack_from_the_ddr_sdram), .local_wdata_req_from_the_ddr_sdram (local_wdata_req_from_the_ddr_sdram), .reset_phy_clk_n_from_the_ddr_sdram (reset_phy_clk_n_from_the_ddr_sdram),
//io signals
.mem_addr_from_the_ddr_sdram (ddr_a), .mem_ba_from_the_ddr_sdram (ddr_ba), .mem_cas_n_from_the_ddr_sdram (ddr_cas_n), .mem_cke_from_the_ddr_sdram (ddr_cke), .mem_clk_n_to_and_from_the_ddr_sdram (clk_to_sdram_n), .mem_clk_to_and_from_the_ddr_sdram (clk_to_sdram), .mem_cs_n_from_the_ddr_sdram (ddr_cs_n), .mem_dm_from_the_ddr_sdram (ddr_dm), .mem_dq_to_and_from_the_ddr_sdram (ddr_dq), .mem_dqs_to_and_from_the_ddr_sdram (ddr_dqs), .mem_ras_n_from_the_ddr_sdram (ddr_ras_n), .mem_we_n_from_the_ddr_sdram (ddr_we_n) );
endmodule
