21602 Discussions
Pin Assignment for jesd204b using Apollo Agilex 7 and AFE79 EVM
Amit4
I am trying to implement the design example of JESD204B on the Apollo Agilex 7 board and using AFE79 EVM; these boards are connected with the help of FMC.
I need help with pin assignments, like mgmt_clk,refclk_core,refclk_xcvr, etc.; how do I assign pins for these(all pins should match for the Agilex FPGA and AFE79 EVM?
and how SPI module pin should be assigned?
Harshx
Please share details about Apollo Agilex 7, Device ID/OPN number?
Are you using Quartus Prime Pro?
Harsh M
Amit4
Hi Harsh,
Intel® Agilex® SoC FPGA : AGFB014R24B1E1V/AGFB014R24B2E2V
Product Line: AGFB014R24B
Device ID (32 bits): Version (4 bits): 1100
                                   Part Number (16 Bits): 0011 0100 0001 1010
Yes I am using Quartus Prime Pro software version 24.1
Harshx
You can refer the following:
1. Agilex™ 7 FPGA F-Series and I-Series Clocking and PLL Overview (intel.com)
You can refer this if you get error at Fitter stage in Quartus. This will give you a better understanding for clocking scheme for Agilex 7.
1.7.11. HPS SPI Pins (intel.com)
Harsh M
