21615 Discussions
Pipe to quartus_asm broken but process still running, terminating quartus_asm
I am facing a issue while running a design on QUARTUS 15.0 version.
The error comes after the assembler stage while compiling the design. Following is the log -
Info: Total CPU time (on all processors): 00:13:54
Info: *******************************************************************
Info: Running Quartus II 64-Bit Assembler
Info: Version 15.0.0 Build 145 04/22/2015 SJ Full Version
Info: Processing started: Mon Mar 14 17:40:52 2016
Info: Command: quartus_asm --read_settings_files=off --write_settings_files=off system -c system
Info: Quartus II 64-Bit Assembler was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 7081 megabytes
Info: Processing ended: Mon Mar 14 17:42:34 2016
Info: Elapsed time: 00:01:42
Info: Total CPU time (on all processors): 00:01:41
Error (112002): Pipe to quartus_asm broken but process still running, terminating quartus_asm
Error (293007): Current module quartus_asm ended unexpectedly
ERROR: Error(s) found while running an executable. See report file(s) for error message(s). Message log indicates which executable was run last.
while executing
"execute_flow -compile"
(file "synthesis_tcl.tcl" line 21)
Error (23031): Evaluation of Tcl script synthesis_tcl.tcl unsuccessful
Error: Quartus II 64-Bit Shell was unsuccessful. 3 errors, 122 warnings
Error: Peak virtual memory: 935 megabytes
Error: Processing ended: Mon Mar 14 17:42:37 2016
Error: Elapsed time: 00:09:04
Error: Total CPU time (on all processors): 00:15:03
PS - there is enough memory space and OS used is linux.
Any help would be worth.
Anmag
