hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
Programmable Devices
21228 Discussions
Please provide the RoHS certificate and Material declaration sheet for part#EP20K160EFC484-2N.
Chaitanyaeinfo
1)Please provide the RoHS certificate and Material declaration sheet for part#EP20K160EFC484-2N.
2)As per the customer "There are only 6 substances confirmed for ROHS of this material, please help confirm whether there are 10 substances confirmed.
Or can you confirm the following ROHS version? EU directives 2011/65/EU and amendment 2015/863/EU"
Kindly advise Does this part has an ROHS version of EU directives 2011/65/EU and amendment 2015/863/EU.
Note: We are one of your distributors. If you are not able to answer the above questions, then please provide the direct email contact (Compliance team)who can help us in this case.
NazrulNaim_Intel
Sorry for the delay. Thank you for reaching out. Allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
Nazrul Naim
NazrulNaim_Intel
For your information, this product is RoHS Compliant with RoHS Directive 2011/65/EU and as amended by Directive 2015/863. For the material Declaration Sheet can be obtained through the link below.
Link : https://cdrdv2.intel.com/v1/dl/getContent/693838?fileName=EP20K160EFC484-2N_20191130040555_v1.xml
Below is the step how to open XML file in Excel
  1. Open a new blank Excel file
  2. Click on Developer tab, then click Import
  3. Select the xml file you want to import, then click Import
  4. Click "OK" on pop-op information, and also "OK" on where to Import data
  5. The table will then be generated, and you will see a lot of "blank" cells due to the long text of the "legalDef" column AK.
  6. I recommend to delete column AK so that the other columns will display better:
Hope that answers your question.
Nazrul Naim
NazrulNaim_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided, for now I will set this case to Close-Pending.
Nazrul Naim
