21602 Discussions
Possibility to avoid configuration power requirements for single-supply MAX10 by using nconfig
taka7
I am currently designing a circuit using 10M04SCE144I7G, and I have a question about the power requirements for configuration.
[Question premise]
- VCC_ONE, VCCA, and VCCIO are supplied from the same 3.3V switching regulator.
- According to the "MAX10 Configuration User Guide", the power rise time must be within 10ms.
- The recommended power supply voltage for the 3.3V single power supply MAX10 is 3.135~3.465V (3.3V±5%) for VCC_ONE, VCCA, and VCCIO.
(Question 1) Can the power rise time be completely ignored by the reset IC driving nCONFIG low until the power supply voltage reaches a certain value?
(Question 2) If question 1 is possible, what is the appropriate threshold voltage for the reset IC?
Labels (2)
Fakhrul
Hi taka7,
You refer to Intel® MAX® 10 Power Management User Guide for more details on your questions.
In response to your question:
<ANS> No, the power rise time cannot be completely ignored, even if nCONFIG is held low by a reset IC. According to the MAX 10 Power Management User Guide, the Power-On Reset (POR) circuit monitors the power rails (VCC_ONE, VCCA, and VCCIO for banks 1B and and ensures they reach the recommended operating voltage within the specified ramp time. If the ramp time (tRAMP) is not met, the FPGA may not exit the reset state properly, and configuration could fail​
However, if nCONFIG is held low, the FPGA will not start configuration until it is released. This means that the timing requirement for configuration start can be controlled, but it does not override the need for power rails to ramp up properly to meet the device specifications.
<ANS> If you are using a reset IC to hold nCONFIG low, the threshold voltage should be selected to ensure that all monitored power supplies (VCC_ONE, VCCA, and VCCIO of banks 1B and have reached a stable level above the POR trip voltage before releasing nCONFIG.
Based on the recommended voltage range for a 3.3V single-supply MAX 10 device (3.135V to 3.465V), a good reset IC threshold would be around 3.0V to 3.1V. This ensures that the supply is within the acceptable range before the FPGA attempts to configure. Additionally, you should verify the POR delay (typically 2.5 ms) to ensure stability before releasing nCONFIG​.
Fakhrul
Fakhrul
Hi taka7,
Fakhrul
taka7
Thank you Fakhrul.
My question has been resolved.
Fakhrul
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
