21611 Discussions
Print Nios II Console
I am outputing a large amount of debug data to he NIOS II console and need to be able to check this . Is there a way of saving the contents of the console to a file or print it out.
All help would be appreciated
you can try nios2-terminal > log.txt
It is fine, i need to log some data from my board.
And was it possible to make some script, which can to log the data from jtag uart to one file every maybe 5 minutes ?
I mean every 5 minutes it creates one file ... log0905.txt at 9:05, log0910.txt at 9:10 ...etc.
Hi all,
my colegue make this script, which work (every 10 minutes save one log file)
# !/bin/sh
x=0
while [ 1 ] ; do
echo 'begin save data...'
nios2-terminal > ukladam$x.csv &
sleep 600
echo 'end saving data...'
# kill nios2-terminal
ps -ef | grep "nios2-terminal" | awk '{print $2}' | xargs kill
# increment variable
x=$(($x+1))
done
Now it works ! :)
Jan Naceradsky
