21604 Discussions
Problem to include ALTASMI_PARALLEL to Cyclone III project.
I'm trying to include ALTASMI_PARALLEL in Cyclone III project.
Mega Wizard generated the following code
LIBRARY ieee; USE ieee.std_logic_1164.all; LIBRARY altera_mf; USE altera_mf.all; ENTITY EPCS_CONT IS PORT ( addr : IN STD_LOGIC_VECTOR (23 DOWNTO 0); clkin : IN STD_LOGIC ; datain : IN STD_LOGIC_VECTOR (7 DOWNTO 0); rden : IN STD_LOGIC ; read : IN STD_LOGIC ; write : IN STD_LOGIC ; busy : OUT STD_LOGIC ; data_valid : OUT STD_LOGIC ; dataout : OUT STD_LOGIC_VECTOR (7 DOWNTO 0); illegal_write : OUT STD_LOGIC ); END EPCS_CONT; ARCHITECTURE SYN OF epcs_cont IS SIGNAL sub_wire0 : STD_LOGIC ; SIGNAL sub_wire1 : STD_LOGIC ; SIGNAL sub_wire2 : STD_LOGIC ; SIGNAL sub_wire3 : STD_LOGIC_VECTOR (7 DOWNTO 0); COMPONENT altasmi_parallel GENERIC ( data_width : STRING; epcs_type : STRING; intended_device_family : STRING; lpm_hint : STRING; lpm_type : STRING; page_size : NATURAL; port_bulk_erase : STRING; port_fast_read : STRING; port_illegal_erase : STRING; port_illegal_write : STRING; port_rdid_out : STRING; port_read_address : STRING; port_read_rdid : STRING; port_read_sid : STRING; port_read_status : STRING; port_sector_erase : STRING; port_sector_protect : STRING; port_shift_bytes : STRING; port_wren : STRING; port_write : STRING; use_eab : STRING ); PORT ( illegal_write : OUT STD_LOGIC ; read : IN STD_LOGIC ; addr : IN STD_LOGIC_VECTOR (23 DOWNTO 0); busy : OUT STD_LOGIC ; clkin : IN STD_LOGIC ; data_valid : OUT STD_LOGIC ; datain : IN STD_LOGIC_VECTOR (7 DOWNTO 0); rden : IN STD_LOGIC ; write : IN STD_LOGIC ; dataout : OUT STD_LOGIC_VECTOR (7 DOWNTO 0) ); END COMPONENT; BEGIN illegal_write <= sub_wire0; busy <= sub_wire1; data_valid <= sub_wire2; dataout <= sub_wire3(7 DOWNTO 0); ALTASMI_PARALLEL_component : ALTASMI_PARALLEL GENERIC MAP ( data_width => "STANDARD", epcs_type => "EPCS16", intended_device_family => "Cyclone III", lpm_hint => "UNUSED", lpm_type => "altasmi_parallel", page_size => 256, port_bulk_erase => "PORT_UNUSED", port_fast_read => "PORT_UNUSED", port_illegal_erase => "PORT_UNUSED", port_illegal_write => "PORT_USED", port_rdid_out => "PORT_UNUSED", port_read_address => "PORT_UNUSED", port_read_rdid => "PORT_UNUSED", port_read_sid => "PORT_UNUSED", port_read_status => "PORT_UNUSED", port_sector_erase => "PORT_UNUSED", port_sector_protect => "PORT_UNUSED", port_shift_bytes => "PORT_UNUSED", port_wren => "PORT_UNUSED", port_write => "PORT_USED", use_eab => "ON" ) PORT MAP ( read => read, addr => addr, clkin => clkin, datain => datain, rden => rden, write => write, illegal_write => sub_wire0, busy => sub_wire1, data_valid => sub_wire2, dataout => sub_wire3 ); END SYN;
I include it in TOP
component EPCS_CONT is port ( addr : IN STD_LOGIC_VECTOR (23 DOWNTO 0); clkin : IN STD_LOGIC; datain : IN STD_LOGIC_VECTOR (7 DOWNTO 0); rden : IN STD_LOGIC; read : IN STD_LOGIC; shift_bytes : IN STD_LOGIC; write : IN STD_LOGIC; busy : OUT STD_LOGIC; data_valid : OUT STD_LOGIC; dataout : OUT STD_LOGIC_VECTOR (7 DOWNTO 0); illegal_write : OUT STD_LOGIC ); end component; signal addr_sig : STD_LOGIC_VECTOR (23 DOWNTO 0); signal datain_sig : STD_LOGIC_VECTOR (7 DOWNTO 0); signal rden_sig : STD_LOGIC; signal read_sig : STD_LOGIC; signal shift_bytes_sig : STD_LOGIC; signal write_sig : STD_LOGIC; signal busy_sig : STD_LOGIC; signal data_valid_sig : STD_LOGIC; signal dataout_sig : STD_LOGIC_VECTOR (7 DOWNTO 0); signal illegal_write_sig : STD_LOGIC; U_EPCS_CONT : EPCS_CONT port map ( addr => addr_sig, clkin => CLK_30MHZ, datain => datain_sig, rden => rden_sig, read => read_sig, shift_bytes => shift_bytes_sig, write => write_sig, busy => busy_sig, data_valid => data_valid_sig, dataout => dataout_sig, illegal_write => illegal_write_sig );
While compiling get error - Error (12152): Can't elaborate user hierarchy "EPCS_CONT:U_EPCS_CONT|altasmi_parallel:ALTASMI_PARALLEL_component"
What's the problem?
shift_bytes input is not present in your component entity but present in your component instanciation
--- Quote Start ---
--- Quote End ---
I removed the shift_bytes input - still the same problem.
--- Quote Start ---
--- Quote End ---
There are detailed error messages above this line. Look for the first red line in the compilation report or click the "Show error messages" filter.
--- Quote Start ---
Error (272006): shift_bytes input port must be used in combination with page write circuit
Error (287078): Assertion error: Valid clear box generator not found or Errors encountered during clear box generation
Error (12152): Can't elaborate user hierarchy "altasmi_parallel:ALTASMI_PARALLEL_component"
--- Quote End ---
You are obviously ignoring some requirements for the component, review the manual thoroughly.
--- Quote Start ---
--- Quote End ---
You are right. But I don't know how to deal with the errors.
What should I do wit this?
ASSERT (CBXI_PARAMETER != "NOTHING")
REPORT "Valid clear box generator not found or Errors encountered during clear box generation"
Oh, I found the problem - it should be page_size => 1, in Single byte write mode.
What mode is better to use - Single byte write or Page write?
