21609 Discussions
Problem when doing a bulk erase using JTAG
I am trying to bulk erase a EPM7512AETC144-10 using a 68HC09 microcontroller connected to the JTAG pins of the MAX7000. According to the SVF file, a bulk erase requires the following instructions:
!BULK ERASE
SIR 10 TDI (00A);
RUNTEST 1000 TCK;
So I implemented a function in C to match theses instructions:
int j=0;
short int IRData[10]={0,1,0,1,0,0,0,0,0,0}; // 1st 10 bits of 0x00A (least significant bits first)
///-----------Disable Interrupt------
# ifdef __HIWARE__
asm TPA;
asm PSHA;
asm SEI;
# else
# pragma asm
TPA
PSHA
SEI
# pragma endasm
# endif
PTD_PTD0 = 0; //TMS=0
for (j=0;j<100;j++)clock_Cycle(); //Run test idle for 1ms at least
PTD_PTD0 = 1; //TMS=1
clock_Cycle(); //Select DR Scan
clock_Cycle(); //Select IR Scan
clock_Cycle(); //Capture IR Scan
clock_Cycle(); //shift IR Scan
for (j=0;j<10;j++)
PTD_PTD2 = IRData[j]; //Shifting data bits
clock_Cycle();
clock_Cycle(); //EXIT IR
clock_Cycle(); //UPDATE IR
clock_Cycle(); //run test idle
///-----------Enable Interrupts------
# ifdef __HIWARE__
asm PULA;
asm TAP;
# else
# pragma asm
PULA
TAP
# pragma endasm
# endif
break;
However, when this function is called, the MAX7000 doesn't seem to be erased and is even still running. Does anybody see something wrong with this function? Or are there some instructions to perform before theses? I checked the waveforms for TMS and TDI and everything seems to be ok (See the attachment).
Thanks ,
Cyril
My recommendations:
1. Check the TDO output with the scope as well. It should be high-z in all TAP controller states except shift DR and shif IR. So you can see if you managed to move the TAP controller to the appropriate state.
2. There should be a TAP controller reset at the very beginning of your sequence
for (j=0;j<5;j++)clock_Cycle(); // test logic reset
clock_Cycle(); // test idle
Hope that helps,
Harald
