21607 Discussions
Using GCLK by a Quartz Crystal
Hi all,
Can I use a quartz crystal to drive the GCLK pin of FPGAs? I mean just like the microcontroller XTAL pin which needs a quartz crystal with 2 capacitors?
Thanks in advance.
No, you need a crystal oscillator or an unbuffered CMOS inverter to build an oscillator.
thnx man for ur fast answer ;)
That's an interesting question, though! Has anybody here ever tried to use the FPGA itself to build a crystal oscillator? It's quite easy to have a simple inverter from on pin to another. So after configuration, the FPGA should oscillate with the crystal. Any experience with that?
There have been some discussions of this on the comp.arch.fpga newsgroup. It isn't at all reliable.
Leon
